window help?
Old Nov 26, 2018 | 02:38 AM
cjben's Avatar
cjben
window help?
1996 f250. Driver's side window has been off track forever but would still roll up and down. well the door got slammed too hard and the window glass fell to the bottom of the door. I took the door panel off to lift it back up and put it back on track,but there is no way my hands can fit into the tiny holes. Any tricks on how to get the window out?
Old Nov 26, 2018 | 08:10 AM
Scndsin's Avatar
Scndsin
A window that moves but window falls is usually the nylon slugs in the gear drive attached to the motor.
I lift the window into the up position & take a pair of needle-nose vice grips & clamp the side track below the horizontal channel that holds the glass.
Drill out 1 of the 2 rivets of the vertical support bar that covers the biggest access hole & rotate it out of the way.
Drill out the rivets that hold the regulator/ motor assembly & unbolt the regulator (scissor & big gear assembly) from the motor while still inside the door rather than trying to take them out together.
Take out motor & disassemble the gear drive & install the nylon slugs.
If one of the vertical channels is loose, you should have access to see where.
Hope this helps.
Old Nov 26, 2018 | 03:31 PM
Binkowski's Avatar
Binkowski
I take the speaker out too. That gives you some more room to grab the window and motor.
Steve Kingery
Apr 5, 2019 02:31 AM
Odisvan
Feb 11, 2019 04:42 PM
D Ray
Jul 28, 2009 10:01 AM
ty20404
Jun 24, 2008 05:26 AM
pherve
Jun 7, 2007 04:21 PM
