Balancing..
Old Nov 26, 2018 | 12:43 AM
Jmudweiser's Avatar
Jmudweiser
Balancing..
Is balancing recommended when rebuilding a 7.3?
its .20 over w all OEM parts. Stock forged rods have been cryotreated, and I’m installing a main girdle. Building for over 600hp, but plan on just having 4-450 hp. with 205/30 injectors.
Old Nov 26, 2018 | 01:45 AM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Any engine worth rebuilding is worth balancing. I would not even hesitate balancing any engine that has any new components.
Old Nov 26, 2018 | 10:58 AM
Jmudweiser's Avatar
Jmudweiser
Ok cool. Thank you!
Old Nov 26, 2018 | 11:33 AM
Fat Diesel's Avatar
Fat Diesel
Normally I'd say the same thing, but with a big diesel that barely turns 3k RPM's I might weigh the costs vs the benefit.
Old Nov 26, 2018 | 12:17 PM
Dan V's Avatar
Dan V
And part of the issue I found was finding a balancing shop that had the weight required to do it.
Old Nov 26, 2018 | 12:49 PM
Jmudweiser's Avatar
Jmudweiser
Those are concerns my machine shop pointed out, low rpm, and they needed to make weights.
Old Nov 26, 2018 | 12:51 PM
FordTruckNoob's Avatar
FordTruckNoob
I couldn't even find one to do a simple align hone of the block's crank journals in my neck of the woods. Ended up shipping the whole ****show to Swamps in TN. Once there, it got about all the machining one can do on a 7.3 and balanced
Old Nov 26, 2018 | 04:07 PM
Fat Diesel's Avatar
Fat Diesel
Depending on how crafty you are, you could get a scale and grind material off each piston and rod until it's as light as the lightest one. That's the cheap out.
Old Nov 26, 2018 | 06:09 PM
Dan V's Avatar
Dan V
I borrowed a scale and that's the "out" I took.
Jmudweiser
Oct 14, 2018 11:15 PM
RodSC
13
Mar 20, 2018 06:47 AM
phoskins
Mar 5, 2018 10:35 AM
TruckoffFord
Apr 8, 2008 11:13 PM
