Disk Brake Swap question
Old Nov 25, 2018 | 08:42 PM
papa86f150's Avatar
papa86f150
Quick question, I am in the middle of my 74-79 disk brake swap on my 67 and I have misplaced both bolts to the caliper. I could not find it on LMC or any of the others. Can I run what ever bolt just to make it work or does it need to be that odd shaped bolt? Also I will be upgrading to power brakes. Now I have the correct master cylinder and a new disk/drum prorationing vale. Do I replace the factory one up under the frame with the new one or just run both? I see most guys and gals mount it under the booster. Any help would be awesome!
Old Nov 26, 2018 | 01:26 AM
GaryKip's Avatar
GaryKip
About the missing bolt- Do you know what size it is? If so you can buy a grade 8 replacement from the bolt depot or a local NAPA.
Old Nov 26, 2018 | 07:10 AM
ultraranger's Avatar
ultraranger
You can get the correct caliper key bolts, in a caliper key set, from the parts store.
greentruck72
Feb 21, 2015 09:01 PM
79 f-150 guy
Jul 30, 2010 12:19 AM
captain p4
Offroad & 4x4
Aug 2, 2007 03:58 PM
