5th wheel prep package
Old Nov 21, 2018 | 08:29 PM
Frank2410's Avatar
Frank2410
I am looking for a fifth wheel puck system. The factory one is on national backorder. Any recommendations? Will the Reese 30138-26 fit? It is a 2017 F250 Super Duty
Old Nov 22, 2018 | 07:09 AM
7591250sd's Avatar
7591250sd
I believe Reese makes the ford oem puck system Item # RP30126 , check at Etrailer. Others on here have added the hitch, requires lifting the bed
Old Nov 22, 2018 | 06:11 PM
lariatbob's Avatar
lariatbob
I ran into that as well. Then started calling smaller dealers in Colorado and found one at a dealer that had ordered several before the backorder. Just keep trying, you may get lucky.......
Old Nov 22, 2018 | 06:13 PM
ford390gashog's Avatar
ford390gashog
B&W makes a very nice system that plugs right in to the factory prep.
Old Nov 23, 2018 | 08:47 AM
hendu4672's Avatar
hendu4672
Not sure if you're looking for a slider/auto slider system or not. Pullrite just release a Ford Factory puck system on their superglide. Demco and B&W also have sliders that will fit in the factory puck system. I'm torn myself. Leaning towards the Demco.
https://www.demco-products.com/rv-to...-prep-package/
NEW OE Puck Series SuperGlide! | Fifth Wheel Hitches by PullRite
https://www.bwtrailerhitches.com/pro...der-ford-pucks
Old Nov 23, 2018 | 02:18 PM
mptjelgin's Avatar
mptjelgin
I just put a Pullrite SuperFifth into my 2019 F-350. It fit perfectly into the factory holes. Took about ten minutes to install. I have a longbed truck so didn't need a slider type hitch.
I've used the PullRite system for 9 years now and very much prefer it to the more common two-jaw systems. PullRite has a jaw that closes completely around the kingpin and eliminates that nagging "is the hitch closed and locked correctly?" issue, along with the attendant pull tests, etc.
If you don't have a hitch yet I'd give this brand a look.
Old Nov 23, 2018 | 07:58 PM
Frank2410's Avatar
Frank2410
I have also found a BC3Z-5F057-A. Woild this work in a 2017 F250?
Old Nov 26, 2018 | 08:21 PM
lariatbob's Avatar
lariatbob
So the way I understood it was that the 2017 had the inner brackets welded on the frame.
The -a part number was for the earlier trucks and came with the 4 brackets whereas the -b was for the 2017 and up and came with the outer brackets only.
My -b kit had all 4, the inners were welded.
So if you can find the -a and it only comes with the outer brackets I have 2 inners I can supply but your truck probably has the welded inners....
It also came with the complete kit to add the in bed trailer wiring.
It is also suggested you replace the bed bolts but I retorqued mine to the required 129 ft lbs and had no issue.
Also just posted about my install.....
https://www.ford-trucks.com/forums/1...l#post18327912
Rockinfigs
May 16, 2018 02:12 PM
truckzilla 34
Oct 11, 2017 11:10 AM
thomabb
All Things Towing
Jan 18, 2017 11:53 PM
Biggziff
6.7L Power Stroke Diesel
Apr 20, 2011 08:11 AM
jstange2
Sep 1, 2010 06:32 PM
