Other Vehicles
Other Vehicles
I did a short search here and I didn't see this thread in my search. If there is one please forgive me. What are your other mechanical pride and joys? For me it is my 1994 Hennessey Dodge Stealth R/T twin turbo. Yes Hennessey tuned the 3000GT / Stealth, it was actually the platform that got him started.
Yes I know that there is a VERY shady past tied to this name. I acquired this car back mid-summer 09 with just over 25,xxx miles on her and this was the sticker on the intake "Y" pipe that got me hunting for more info.
What I discovered is that the original owner of this car was also the owner of the dealership. He wanted "more" from the car and sent a mechanic on a quest to find what was out there for the platform. Hennessey was bankrupt at this time, so everything that was done was bought from Hennessey and installed and tuned at the dealership. Given Hennessey's history that might have been a good thing. I have been able to visually confirm that my car was built to Stage 5 minus the Vein Pressure Converter. As I have modified the car I have kept two factors in thought, 1: What would Hennessey do if this was still a car that they tuned. 2. Put more emphasis on the Track portion of the R/T. Below is a list of what I have done:
Performance:
[Hennessey Stage 5 Tuning]
Flash Tune
*LCD Boost Controller
HKS twin intake
[HKS EVC I]
[TD04 13G's]
[Centerforce clutch]
Ninja Performances 70A fuel pump hot wire
NGK BKR7ES-11’s
MSD Wires
3SX Poly motor mounts
IPS Baffled Oil Pan
GZP Pre-Set Cam Gears (have 3SX's new adjustable)
3rd Gen Lifters
EGR Delete
Krank Vents
Greddy Type S BOV
3SX Pre-Turbo Hard Pipes (powder coated)
3SX Phenolic Spacers
Speedhut Gauges (wideband, fuel pressure, oil pressure, oil temp., water temp.)
Exhaust:
OEM cat-back active exhaust (had HKS D2, but learned it was worse than OEM
Stillen D/P (ceramic coated)
3SX Rear pre-cat delete (ceramic coated)
Suspension:
Custom Tuned G/C Sleeve Kit on ECS Struts
TEC Performance front strut bar
TEC Performance rear strut bar
Tein front & rear pillow strut mounts
Saner front & rear sway bar
Brakes:
AMSOil Synthetic DOT-4 Brake Fluid
3SX SS lines
SuperCarEngineering W.I.D.E. floating rotor brake kit
SuperCarEngineering caliper stiffening bolts
Powdered calipers & rotor hats
Panther XP-8(front) / AX-6(rear) brake pads
Titanium shims(front)
JDM front brake ducts
Electrical / Misc:
BigTyla Ground kit in 1/0GA
880CCA battery
3KGT2NV Allen head bolt kit
Seattlevr4 roller bearing STS
Morgan front splitter
RetroSpec Side Splitters
Yellow & black C/F dash kit
Custom wrapped steering wheel in suede with yellow stitching
April's Turbo propeller oil cap
Custom made "Hennessey" spark plug cover and door sill plates
Security:
Viper 5902 Alarm / Remote start
Four 110Db piezo sirens (gives great headache)
Smart start
Glass sensor
Tilt sensor
Hatch release
[ ] Hennessey mods done to the car before I bought it that I could confirm that was on the car.
* things yet to be installed, and that is not counting the spare transmission that will be rebuilt with JDM final gearing.
Performance:
Flash Tune
HKS twin intake
[HKS EVC I]
[TD04 13G's]
NGK BKR7ES-11’s
MSD Wires
IPS Baffled Oil Pan
3rd Gen Lifters
EGR Delete
Krank Vents
Greddy Type S BOV
Exhaust:
Suspension:
Brakes:
3SX SS lines
Electrical / Misc:
880CCA battery
Security:
Smart start
Glass sensor
Tilt sensor
Hatch release
shorebird
General Automotive Discussion
04-05-2009 11:57 AM
