Been running great, and today started running rough, then died while idling and would not restart. It tried to...acted like wasn't getting enough fuel, or was flooded. After sitting for 30 minutes, it started right. Ran, but no power. After about twenty minutes, it died again. During this time, the display on my Edge showed 0 boost, 0 engine temp & 0 trans temp. Then it showed temps but 0 boost.
Where to start diagnosis?
I have FORScan...what PID's should I look for?
Does anyone know a good 6.0 tech in Houston or Kingwood/Porter Texas?
Next time it dies pull your fuel filter and see if it's empty. My monitor sometimes does that to if you pic one of the pids and exit out usually starts working again. Was this during cold start or was it warmed up
