runs rough when at normal running temp.
Old Apr 22, 2011 | 04:50 PM
txtruck44's Avatar
txtruck44
Question runs rough when at normal running temp.
Hey yall, this is my first post. Im having problems with my 03 250 6.0l. Last week because of laziness i bypassed the fuel station to get on home and going by miles to empty display I thought it would be fine but it lied and i ran out of diesel. I put more in it cranked it up and every thing was fine until 2 days ago. After my truck had warmed up it started running rough. I stopped and killed then cranked it back up and it seemed to be running fine then after 30-45 seconds it started to run rough again. So i again stopped killed and recranked. I done this several times and every time after 30-45 seconds it would run rough (once it died while driving down the road but cranked right back up) but only if the engine was warm. if i was sitting idle then 30-45 seconds after i cranked it the rpms would jump from 700 to 900 and would not go back down until i recranked. There are no oil leaks that i can see. My filters are clean. I also verified fuel is being delivered to the fuel filter housing when the key is turned on. Ive recently read about ipr, icp and cps but do not want to just start changing parts. Any ideas?
Old Apr 22, 2011 | 05:27 PM
cheezit's Avatar
cheezit
sounds like you killed an injector or 2
Old Apr 23, 2011 | 02:23 AM
txtruck44's Avatar
txtruck44
that sux!!!
inutaishou111
Feb 3, 2014 08:21 PM
rickylee75160
Aug 28, 2011 05:06 PM
carltonwebb
Oct 19, 2010 01:56 AM
Baggins
Aerostar
26
Mar 16, 2008 12:20 AM
MarkPoorman
15
Dec 17, 2004 05:03 PM
