I had my dealer replaced a front u-joint last week. Over the weekend I found I had no 4wd with the hubs in auto mode but did have traction when I locked the front hubs.
Bad u-joint install?
The auto hubs are vacuum operated. They may have not connected the vacuum line? I would take it back and ask them what they did to prevent 4x4 operation.
Hopefully they get it sorted out for you. I have had to replace the front axle seal a few times, when they leak (or any other leak in the vacuum system) the system can't pull vacuum to lock the hubs. It is usually an easy fix, although replacing the front axle seal does involve some labour...
It’s a vacuum pulse signal to pull in the hubs in 4x4 auto, so it shouldn’t blow anything, or build pressure, and the vent is on the diff, which is a separate chamber/part of the axle. I’d guess that some moving part within the hub is installed backwards or in the wrong Seanad is pushing the seal. But back to what Jim said, if it occurs when they’re manually engaged that points to an assembly issue.
