Repair question
I had my dealer replaced a front u-joint last week. Over the weekend I found I had no 4wd with the hubs in auto mode but did have traction when I locked the front hubs.
Bad u-joint install? |
The auto hubs are vacuum operated. They may have not connected the vacuum line? I would take it back and ask them what they did to prevent 4x4 operation.
Yep, Vacuum pump is gone or not connected.
Thank you. It's going back Monday morn.
Not fun to encounter a foot of snow and find out my 4WD has an issue. |
Originally Posted by MG250
(Post 18318752)
Not fun to encounter a foot of snow and find out my 4WD has an issue. This is one place I'm glad they kept the manual option. |
Agreed. I ended up doing that to get moving.
Hopefully they get it sorted out for you. I have had to replace the front axle seal a few times, when they leak (or any other leak in the vacuum system) the system can't pull vacuum to lock the hubs. It is usually an easy fix, although replacing the front axle seal does involve some labour...
Dealer service called me. The axle seal failed, covered under warranty.
(Post 18327572)
2015 with 83k on it.
Good news is they can replace the seal...bad news is every time the dealership puts the truck into 4wd auto it blows out the seal again.
Any thoughts? |
(Post 18328878)
(Post 18329895)
Any thoughts? |
Originally Posted by KR2012F250
(Post 18332965)
Check for a plugged vent line. Diff pressures up when diven.
It’s a vacuum pulse signal to pull in the hubs in 4x4 auto, so it shouldn’t blow anything, or build pressure, and the vent is on the diff, which is a separate chamber/part of the axle. I’d guess that some moving part within the hub is installed backwards or in the wrong Seanad is pushing the seal. But back to what Jim said, if it occurs when they’re manually engaged that points to an assembly issue. |
