Adding Remote Start
Old Nov 19, 2018 | 10:17 AM
Ram2Ford's Avatar
Ram2Ford
Adding Remote Start
Good morning all,
I have searched and really don't have the time to search through 70K threads to find the answer. My father just purchased a 2017 SD Lariat with plenty of options but it does not have the remote start. Anyone add an aftermarket that they are happy with or does Ford offer something that would allow him to have a Ford fob? He really doesn't want to add another fob if he can help it. Thanks in advance.
Old Nov 19, 2018 | 10:35 AM
cub22908's Avatar
cub22908
Originally Posted by Ram2Ford
Good morning all,
Can't help you with the factory fob question but want to give a warning about the extra fob solution. Your father is correct in wanting to avoid that, we have the dealer installed "Ford" remote start in a ford car. All it requires is a double press to start the car. We have found the car running a couple times in the closed garage, who knows how many times it ran we don't know about. That button can easily get pressed twice when in your pocket. The factory fob requires the lock button pressed then the start button double pressed. Just something to keep in mind if you have to settle for the extra fob solution, it in my mind is unacceptably dangerous unless they changed it.
Old Nov 19, 2018 | 11:28 AM
yitbos1's Avatar
yitbos1
Good morning all,
12volt solutions. Link below. Installed a couple months ago and works flawlessly with ford oem key fob. Super easy install. Good luck
​​​​​​https://www.12volt.solutions/collect...t-no-horn-honk
Old Nov 19, 2018 | 11:40 AM
'18_F250_4x4's Avatar
'18_F250_4x4
https://www.ford-trucks.com/forums/1542582-installed-ford-remote-start-on-2018-xl.html
Good morning all,
https://www.ford-trucks.com/forums/1...n-2018-xl.html
Old Nov 19, 2018 | 11:50 AM
Ram2Ford's Avatar
Ram2Ford
Originally Posted by '18_F250_4x4
This only works for '18 and newer.
I do like the 12 Volt solution. I think he'll go for that.
Thanks
Old Nov 19, 2018 | 11:57 AM
'18_F250_4x4
It the comments there are truck owners that say it works on the '17s as well.
I will be doing this to my truck and read all the comments to see what others were saying. I hope it works for you.
Old Nov 19, 2018 | 05:03 PM
Ram2Ford's Avatar
Ram2Ford
Well, I didn't look at it carefully enough. Shoot, that is much cheaper as well. Thanks for enlightening me!!!
Old Nov 19, 2018 | 08:51 PM
Tbc420's Avatar
Tbc420
Have a 12volt one on mine. Only complaint is that the 12 volts doesn’t turn on heat / ac or front defroster even if left on when truck turned off. My only complaint about it but engine is hot when get it so heat comes out as soon as key is turned
Old Nov 20, 2018 | 08:15 AM
'18_F250_4x4
All good brother just give us a install write up report when youre all done.
Old Nov 20, 2018 | 12:06 PM
jimzpsd's Avatar
jimzpsd
I think you need to rent their module for $85 to set up your control options in your settings screen.
Old Nov 20, 2018 | 01:30 PM
lemcat4533's Avatar
lemcat4533
Remote start
Will let you tomorrow picking up 2018 SD and having the remote start added along with garage door opener as well. Using the OEM key fob that came with truck. Hope to pass on good news.
Old Nov 20, 2018 | 03:58 PM
robeyster's Avatar
robeyster
Thanks
This will work on other years I bought it for my 2017 F350 and it works. very simple install.
Old Nov 20, 2018 | 03:59 PM
robeyster's Avatar
robeyster
You can do all this with forscan. You can go in and turn on the option to be in your gauge cluster.
Old Nov 20, 2018 | 06:19 PM
jimzpsd's Avatar
jimzpsd
Nice...thank you
White gold
Mar 24, 2026 08:06 AM
pdombrowicki
6.4L Power Stroke Diesel
23
Sep 16, 2021 10:00 AM
jboworth2008
2009 - 2014 F150
Mar 25, 2015 05:40 AM
Jay
Mar 11, 2014 11:06 PM
rebel_gtc
16
Sep 29, 2004 08:35 PM
