Dog bones
Old Nov 18, 2018 | 10:50 PM
donnybigsky's Avatar
donnybigsky
Dog bones
This has probably been asked before...can upside down dog bones in 1992 302 (f150) cause oil drain back...am experiencing clatter at startup after a few hours. Oil pressure then climbs to 50 psi and quiets down...new pump, checked screen, two new wix filters. This thing is makin me nutz.
Old Nov 18, 2018 | 11:29 PM
Conanski's Avatar
Conanski
Lifter dogbones? If so then no they aren't part of the pressurized oil system. Startup clatter is usually an oil filter thing, try a different filter.. something with a metal backdrain valve.
Old Nov 18, 2018 | 11:53 PM
raystankewitz's Avatar
raystankewitz
Wix Gold is about as good as it gets with a metal drainback valve. Unfortunately, that is the only check valve in the SBF Windsor oiling system. Past getting hold of several bad Wix filters, loose lifter to lifter bore clearance could be the culprit but not likely. I'm out of ideas here so I'll let someone else step in and take a shot at it.
redfishtd
2004 - 2008 F150
Mar 4, 2019 03:14 PM
portagoosey
Aug 16, 2018 08:32 AM
Rasputin53
15
Nov 11, 2015 12:32 PM
88F-150pimp
Mar 12, 2005 05:17 PM
rusty70f100
Oil & Lubrication
17
Oct 15, 2003 07:17 PM
