IPR question
From Page 45 of the 6.0L Coffee Table Book
https://www.ford-trucks.com/ford-man...ble%20Book.pdf
• Cam/Crank Sync: SYNC is achieved when the PCM receives a signal from the Crankshaft sensor and Camshaft sensor indicating they are working and in time. If the Crankshaft and Camshaft sensors are working improperly, the PCM cannot calculate engine speed or cylinder position, preventing fuel delivery.
• No SYNC (Cam/Crank) with an RPM signal typically is a faulty CMP sensor/circuit problem. • No SYNC (Cam/Crank) and no RPM signal, typically is a faulty CKP sensor/circuit problem.
• FICM SYNC: The FICM uses CMPO (Camshaft Position Sensor Output) and CKPO (Crankshaft Position Sensor Output) signals, which are sent by the PCM, to calculate FICM SYNC. FICM SYNC is calculated by the FICM and is the correlation between the camshaft pin and the crankshaft triggers. Once FICM SYNC is achieved, the FICM uses engine speed, MFDES (Mass Fuel Desired), EOT, and ICP to calculate fuel timing, pulse width, and pilot injection usage.
That is a shame, because the start cycle begins with cranking, then cam/crank sync, then a MFD is generated by the PCM and sent to the FICM, then the FICM syncs, and (a long as ICP and rpms are adequate) sends fueling commands (fuel pulse width, etc). So .... if you see a MFD, you know you have cam/crank sync. Also, as stated earlier, since you have rpm, you know that at least you have a functional crank sensor.
That said, a lack of FICM sync will not prevent you from getting the needed high pressure oil pressure when cranking. To prove this, just pull the FICM relay on a working 6.0L and watch the ICP pressure rise when cranking.
You may still have an issue w/ FICM sync, but the issue w/ low ICP seems to be a definite.
"What I have done was apply 12 volts to the IPR, put a 5K pressure gauge in the IPC side, cranked the engine with the starter wire and within several seconds got to at least 2.5K pressure before I stopped cranking, you could hear the engine start to slow own because of the pressure build, so the HPOP was doing its thing (new from Ford)."
From that post, it doesn't seem like a leak or a bad HPOP. That is what led him to a bad IPR possibility.
