'85 F350 towing, am I SOL?
Old Nov 17, 2018 | 02:30 PM
blueridgejwd's Avatar
blueridgejwd
Unhappy '85 F350 towing, am I SOL?
Greeting fellow Blue Oval fanatics! So I'm needing another head or two to justify my thoughts. I've read similar threads here before so I came to the gurus. Thank you in advance for your help.
Last year I purchased a very B.A. 1985 F350, crew cab, LWB. It has been transplanted with a 7.3 idi & T19 4 speed . It has front D60 & rear Sterling 10.25 & I believe 3.55s and is set up for gooseneck (axle code C9). I was only going to use to haul a CJ and misc trailer type work. Front GAWR 4410lbs and rear GAWR is 5,922lbs.
However, now the family desires a large travel camper or fifth wheel anywhere between 11k-14k lbs.
The GVWR is 9,300. To my furious & unbelievable dismay - an old Ford manual listed the GCWR at ONLY 13,000. SERIOUSLY? I can only tow 3,700 lbs with an '85 F350 Diesel? How did they haul equipment in 85!! That doesn't even cover a deck over trailer alone. Am I calculating or reading how GCWR is calculated?
So without getting in the weeds even if I put in 4.10s./4.88s, rear discs, and a $20k comp 7.3 motor with 800hp/1,200 ft/lbs it doesn't matter does it? If I want to haul that much I need a modern frame??
Thank you for your support guys.... I'm going to go bang my head on the wall. I really love that bullnose but has to be safe for family.
Old Nov 17, 2018 | 02:50 PM
Conanski's Avatar
Conanski
You are mostly correct these old trucks didn't have the tow ratings we see now with modern trucks. Your calculations may be a bit off however, you want to subtract the loaded curb weight of the truck ready to travel from the GCWR to get the available trailer weigh and that won't necessarily be the max GVW. The diesel+manual combo does seem to be a limiting factor for this truck though as the max tow rating with a 460 gas and auto is close to 20k lbs.
Old Nov 17, 2018 | 07:32 PM
blueridgejwd
Thank you Conan! So better to spend $$ on a modern HD truck then....all agree?
Old Nov 17, 2018 | 08:13 PM
Conanski's Avatar
Conanski
I agree with that, but be sure to nail down what size trailer you will eventually get before committing to a truck. It seems lots of guys are making the mistake of assuming an modern F250 diesel can tow anything, the powertrain certainly can but the pin weight of a larger 5th wheel can put the combo over the GVWR for that truck making a 1-ton necessary.
Old Nov 17, 2018 | 09:11 PM
HRTKD's Avatar
HRTKD
Boondocker
Out of the box, a 2017+ F-350 is going to give you and the family a much more pleasant drive. Quiet cab, nice amenities and lots of power without having to fiddle around with software or hardware mods.
Old Nov 17, 2018 | 09:12 PM
'65Ford's Avatar
'65Ford
Perhaps do a little more research on your truck. An IDI is not a tow monster but I think it can handle a little more than 2 ton. See if a different axle ratio will help.
Also consider scaling down the camper weight. To me, 5 ton in a newer light weight designed camper is a respectable size and 7 ton is getting up there for even a modern F350 especially if it's a SRW model.
Wouldn't hurt to do a little more figuring before diving into a large fiver and newer truck...The size camper and matching truck you're talking is $50K or more for both.
Old Nov 18, 2018 | 10:36 AM
RA12726's Avatar
RA12726
Banned
That's a good argument if you need to convince your wife - especially if it's the family that want an RV.
Rob
Old Nov 18, 2018 | 01:24 PM
Clubwagon's Avatar
Clubwagon
For reference: My wife and I bought our first travel trailer when I was towing with a 2001 Clubwagon Chateau (Van) with a 7.3 PSD. We bought a 28' trailer and the van towed it easily. However, my wife had reluctantly traveled with me to race weekends (towing my car hauler) in this van. She didn't care for it because it was noisy and she could smell the diesel exhaust occasionally. I upgraded to an '07 F350 PSD, which was an improvement in comfort and quiet. However, she was still somewhat reluctant to make longer trips, especially to go camping, in the truck.
So last fall I traded the '07 F350 on a '17 F250 PSD. This is now her favorite vehicle. While it was intended only for tow duty its her choice for any highway travel and much of our day to day outings together. She prefers it over my car and her 2018 Hyundai Santa Fe for highway travel. So now when we go camping, or to race weekends, in the new truck she is happy to go and distance isn't an issue. Its quiet, comfortable and no diesel exhaust smell. So now we go camping more often and make more adventurous trips. A win win. So consider the new truck.
Old Nov 18, 2018 | 01:30 PM
HRTKD's Avatar
HRTKD
Boondocker
My wife has a 2017 Hyundai Santa Fe Sport. She likes it, but I think she HAS to because she did the research and picked that specific one. Even if she liked the F-350 over the Hyundai I don't think she would admit it. Personally, I really don't care for the ride of the Hyundai. I think it is harsh. Plus, the non-turbo 4 banger is loud. The F-350 has a quieter cabin. The only advantage of the Hyundai on road trips is that I don't have to drive.
Old Nov 18, 2018 | 05:30 PM
blueridgejwd
Conan & 65 Ford... clever& wise!! . While I was prepping for a 1 ton for reasons Conan prescribed (tongue weight,frame, ABS, etc,)I was able to discuss with wife today that since one child is an infant & other a 9 year old we don't need a huge fiver with separate rooms & two sets of stairs that would need baby gates! . If we scale down as 65 said to a a large travel trailer then I can tow that with what I have (will still do rear disc conversion, 4.88 gears, & turbo motor tho to make sure) & that will save us a huge cost on a modern 1 ton SD until the kids are a little older & we really need to upgrade..... SHE AGREED!!! Wooo hooo!!! The best part I get to upgrade the bullnose & use the bull nose!!!
I guess ill upgrade truck later as family needs if a need to upgrade to fiver. I just know here in North Georgia I've seen old late 80s & early 90s 7.3s pull skid steers, tractors, campers, rocks, & timber for years.... they must all be way exceeding their "rating." I couldn't believe it was so low for a 350 Diesel.
thank you guys so much! I appreciate it & am glad I'm a member now!!! I'll be here quite a bit for sure!!! HAPPY TURKEY DAY!!
Old Nov 18, 2018 | 10:16 PM
'65Ford's Avatar
'65Ford
Just a couple notes...
- I wouldn't necessarily forget about getting a fiver now. A little shopping might find one that will work for you. There are "Ultralights" available. I prefer a fiver but I wouldn't push you in either direction because there are good reasons for choosing either one. Just making sure you didn't think I was pushing you one way or the other. Go see some of each and check the specs.
- If rear disc conversion means the truck, then I'd skip that. Front discs on a car/truck are an improvement with no doubt. Rear discs are not really necessary. Some guys like converting to discs on a camper and I can sort of see that.
- Might consider an intermediate axle ratio like 4.10. Calculate your rpms with current axle, 4.10 and 4.88 for comparison. 4.88 seems a bit high for a diesel is the only reason I suggest doing a paper exercise first. Diesels tend to run out of breath around 3000 rpms or lower.
Old Nov 19, 2018 | 09:50 AM
speedfreak78's Avatar
speedfreak78
I'd tow with that truck, just add some power, gears and better brakes. Would a newer truck be nicer? Probably. It's it worth $20K-30k+ more? Not to me. It's not like they weren't pulling weight with them back when they were new. Plus cool old truck beats new truck any day.
Old Nov 19, 2018 | 06:35 PM
blueridgejwd
Speedfreak & 65, I couldn't agree with you both more. One my wallet doesn't want a newer truck & two I don't want a newer truck my passion is in the old iron.
my curb weight at the scale with me in it was 7,080 lbs. On the conservative GCVWR rating of 13k, that gives me "book" towing of 6,000.... I think my beast will be fine pulling 7k-10k don't y'all? If I go w/4.10s, rear disc, & a turbo. I think it will be fine for my current needs. Won't know til i try I guess.
65 is right, they do make ultralight fivers in the 7-10k lb range!! Very cool.
So I think I'll go for it. Heck I disassembled a large barn & stacked it on a 3 axle trailer & hauled it no problems.
Thanks guys!
Old Nov 19, 2018 | 09:13 PM
blueridgejwd
Hey 65, you are dead on with your estimates.... I currently have a 3.55 ratio with 36" tires... at 60 mph that's 1,988 rpms... going to 4.88s puts me at 2,733 rpms while the 4.10 puts me at 2,296. Mine does start cutting back around 2,800-3,000 rpms as u stated so 4.10s look to be best choice. You're good!
Old Nov 20, 2018 | 10:41 AM
Clubwagon's Avatar
Clubwagon
HA! This is out third Hyundai. Her first was a 2010 Elantra, the second a 2013 Sonata and then he bought a manual transmission 2015 Kia Soul (a division of Hyundai), which she dearly loved. All she picked out herself. We initially bought the Elantra in part because Hyundai was a client of mine at the time and we could get it at a significant discount.
Her Soul was totaled by hail earlier this year and the rental car she got during the settlement process was a Santa Fe. We were shopping for a replacement Soul when she ran across this Santa Fe and she decided she liked the rental enough to buy one. Again, her call. She loves it. Its quiet enough and comfortable. We have traveled in it. She regularly makes the 5-6 hour run to her parents home in it. I drive it somewhat regularly and its reasonably good. The AWD system works very well, ride is good, power is adequate handling isn't on par with the best in class but that's not unexpected. Seats are a little wide and flat for my tastes but are OK otherwise. Engine, her's is a Sport 2.0 Turbo, has more than adequate power but is a little more noticeable than ideal but not intrusive. Their her cars and she gets to pick them. She asks me my opinion but I don't tell her what to buy. She had wanted an SUV with AWD and now she has one. She likes it so she's happy and that's what matters.
When we are going somewhere together and I ask her which vehicle she wants to take, unless she wants to drive her car, the response is always "the truck!". If we are planning a trip and are driving she always asks; "we're taking the truck right?".
Her Santa Fe and my Super Duty. Other car behind the truck.
