79 ford ranger
Old Nov 15, 2018 | 06:30 PM
Stuntman13's Avatar
Stuntman13
79 ford ranger
Does anyone have a simple, easy to read diagram of the vacuum lines for a79 ford 351m motor. I got the engine with no vacuum lines and needed a good diagram.
Old Nov 16, 2018 | 08:53 AM
81F(ranken)100's Avatar
81F(ranken)100
This is from Gary's bullnose bible, but might help you out. Maybe the vacuum routings are either the same, or very similar:
351M/400 - Gary's Garagemahal (the Bullnose bible)
Old Nov 16, 2018 | 04:32 PM
1TonBasecamp's Avatar
1TonBasecamp
Is there anything left of the decals under the hood?
Do you know if your truck was originally a CA equipped, or FED rated vehicle?
Is it an F150, 250 or 350? All would be different.
I have the decal for a CA compliant F350 4wd if that might help you. But as a NON-CATALYST vehicle (8500 GVWR or higher) it won't be the same as an lighter vehicle.
Paul
Old Nov 16, 2018 | 05:23 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
OP lives in Missouri, so how can he determine if it was sold new in CA if he doesn't know the history of the truck from day one?
From the DSO code stamped on the 3rd line-far right of the Warranty Plate. If the code is 71 or 72, it was sold new in CA
vjsimone
Apr 8, 2019 01:07 PM
DaBoss460
Feb 1, 2018 08:08 PM
BigCountry1978
Jun 1, 2015 11:42 PM
calbo
20
Jul 6, 2008 09:23 PM
mhope
Sep 1, 2004 10:32 PM
