p0171, p0174, & p0420
Old 11-14-2018, 07:56 AM
blee1ash's Avatar
blee1ash
blee1ash is offline
2002 f-150 5.4., 186000mi
I'm getting codes p0171, p0174 &p0420. The truck runs fine, I haven't noticed any problems other than the CEL. I started last winter with P0171 and P0174 only when very cold air temp. No codes until middle of summer, then started getting just the P0420 code. Now that it has been cold a few times again I'm getting all 3 codes.
For the p0171 and p0174 codes, I have cleaned the maf, changed the fuel filter, and replaced egr tube. I have checked for vacuum leaks with carb cleaner and starting fluid, but not found any. No change still get the codes when very cold. I do believe it may be a intake gasket leak that is only a problem when very cold. I don't know if the p0420 is related to the same problem or something different.
I do know what the codes mean, but not what is causing them.
pp0171& P0174- lean banks 1&2
P0420 - cat. covert. under efficiency
Anyone have ideas whats going on? I don't want to take it to a shop and have them throw parts at it and not fix the problem. I thinking I will just keep driving it until it starts running poorly.
Old 11-14-2018, 11:48 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
That usually doesn't work, the computer is too fast and will compensate before there is any change in RPMs that you can hear. You have to hook up a scan tool (or equivalent) and monitor either the short term fuel trims or the upstream O2 sensor voltages while you spray in order to find the source of the vacuum leak.
Most likely, the P0420 code is a result of having excessive unburned fuel dumped into the converters due to the unrepaired "lean" codes and you've probably ruined the converter due to the delay and continued operation of the truck. Don't be surprised if the other converter is also damaged to some extent but just hasn't yet failed the self tests.
Old 11-14-2018, 01:17 PM
alloro's Avatar
alloro
alloro is offline
Received 4,216 Likes on 2,446 Posts
Follow the PCV valve hose all the way to it's vacuum source and look for any damage or cracks.
Old 11-18-2018, 09:15 AM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
there are two small 1/4 inch ID size hoses about 8 inches long above the drivers valve cover.. on the EGR system.. My 2001 had those two hoses get hard / brittle, and crack at the ends due to heat from the EGR... I had 171- 174 codes.
Old 11-18-2018, 10:52 AM
projectSHO89
I'd have to chalk that up to being a coincidence. There's really no way for the EGR sample hoses to cause a mixture issue unless the DGR valve is also stuck open. They're completely isolated from the intake side of the engine and are only installed on ONE of the two exhaust banks. Besides, the PCM SHOULD have posted EGR system faults if those hoses were not intact.
Old 03-02-2019, 06:05 AM
blee1ash's Avatar
blee1ash
blee1ash is offline
I had the intake manifold gaskets replaced, While doing that found a crack in the intake manifold. Replaced the manifold also.
No more codes. Seems to have fixed the problem.
No I did not damage the concerter. It has not been replaced, and works fine. No p420 code. The intake leak must have caused o2 sensors to read abnormal readings setting that code.
Old 03-03-2019, 01:17 AM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
Only way to be more sure the Cat has not been affected is look at the rear Ox sensor for voltage output.
It may be ok for the near future but fail later on.
Use a Scanner to monitor the rear sensor voltage changes then look at the other side to compare.
These voltages need to be within short limits as an indication the cats are working up to there capacity to store Oxygen.
When the voltage swings to much following the fronts, the PCM program logics it a Cat failure for performance.
Unless you look at both sides you will not know at the present what you have.
Maybe neither side is really good, only one side is degraded etc..
I would do this if you care enough.
This is why Scanners are used to look into these things.
The total system operation is amazing engineering,.for a reason.
The rear sensors don't do any other functions..
Good luck.
Old 03-08-2019, 12:04 AM
CathedralCub's Avatar
CathedralCub
CathedralCub is online now
Thanks for letting us know how it turned out!
Old 03-08-2019, 06:24 AM
projectSHO89
Converter degradation often takes a while to re-manifest itself after such an incident. Don't be surprised if, somewhere down the road, you find that its service life has been severely shortened.
Good luck.
Devine
1997 - 2003 F150
12-28-2018 04:03 PM
Jmurphy5
1997 - 2003 F150
05-12-2016 12:35 PM
TakeMyNuts
3.8 & 4.2L V6
09-26-2015 07:58 AM
morris_506
1997 - 2003 F150
03-21-2010 12:00 PM
johare
1983 - 2012 Ranger & B-Series
03-06-2006 05:46 PM
Quick Reply: p0171, p0174, & p0420
