Sponsored by: Auxito
Lower Intake Compatability?
Old Dec 12, 2018 | 11:46 PM
Clever Name's Avatar
Clever Name
I just pulled the 4.6 out of my '99 F150 and I'm thinking about putting a new lower intake on it. It has the aluminum upper and nylon lower on it right now. I'd rather have an all aluminum intake. It looks like the newer 4.6 truck intakes have a nylon upper and aluminum lower. Can I use that lower with my OE aluminum upper? The upper is the part that actually bolts to the heads, so it shouldn't matter what heads I have (PI or not). I found a new aluminum lower for a fair price, but not fair enough that I'd be OK buying it without knowing if it'll work. My issue with the old lower is that the plastic heat shield between the upper and lower is so deteriorated that I can crumble it in my fist and I honestly removed most of it from the valley with a vacuum. I'm concerned that the actual intake may not be far behind and it would REALLY suck having to pull the intake when it's back in the truck.
Also, where would be a good place to get a service/shop manual for that truck without spending a few hundred dollars? I don't mind if it's a digital copy. I already have the Chilton and Haynes books.
Old Dec 13, 2018 | 12:35 AM
Sam I Am's Avatar
Sam I Am
https://www.rockauto.com/en/moreinfo...786&cc=1354586
Dorman aluminum lower listed for 1999 4.6.
Old Dec 14, 2018 | 05:35 PM
Clever Name
Interesting, thanks. I guess I'll go ahead with it, then. I'll update this thread regarding whether or not it fits.
Old Mar 8, 2019 | 12:53 AM
Clever Name
Update
I ended up cleaning the original nylon intake. I soaked it in a parts washer for a few days, then spent hours washing it with engine decreased, scrubbing with a wire brush (attached to a long handle to get to all the hard-to-reach spots), and finished up by washing it in Dawn. I inspected it pretty thoroughly and it seems structurally sound, so I decided to re-use it. Sorry in advance to anyone else who was wondering if the aluminum lower and upper were compatible. Just check the return policy of whatever company you order the lower from. I'm pretty sure they're compatible.
Old Mar 9, 2019 | 12:57 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Thanks for letting us know what you decided to do. We're all allowed to change our minds.
73 ford guy
Aug 7, 2008 09:15 AM
Jrock909
Jan 23, 2007 09:20 PM
ahall8
1997 - 2003 F150
May 28, 2005 09:54 AM
4x4man514
Nov 27, 2004 10:51 AM
