steering front driver side vibration
Old Nov 13, 2018 | 07:30 PM
danny sangha's Avatar
danny sangha
Im having trouble with 2015 f 150 wheel vibration on driver side / its like rotational vibration ( vibrate with full rotation and thumping vibration ) is it a lower ball joint cause leaked some grease too or bearing . other thing i could think off is rotors too. dealers cant find a cause too.also new wheels and tires are balance and alignment done on them ,ball joints been replaced still having the issue
Old Nov 14, 2018 | 12:43 AM
JKBrad's Avatar
JKBrad
Some things to check for would be radial pull, which is a belt problem within the tire plies, and for proper torque on the lug nuts.
It’s also possible that you have a defective wheel, even though they are new.
Old Nov 14, 2018 | 08:12 AM
scott91370's Avatar
scott91370
I would rotate tires front to rear and see if the problem follows the tires. Then you can start narrowing it down from there.
Old Nov 14, 2018 | 03:56 PM
biz4two's Avatar
biz4two
Arrow
This is really a good video. Might offer some insight...
biz
Old Nov 18, 2018 | 08:51 AM
ArmamentDawg's Avatar
ArmamentDawg
If your truck is a 4X4 it may be the front CV joints on the drivers side.
Old Nov 18, 2018 | 10:51 AM
jr105's Avatar
jr105
Absolutely right. This should be your first step
captain1997
Oct 28, 2012 06:33 AM
GregN
Dec 5, 2009 08:59 AM
Jerrod
Nov 24, 2005 05:26 PM
Talyn
May 26, 2004 08:32 PM
alwaysfixingsomething
23
Jan 20, 2004 05:24 PM
