Turn signal issue
Old Nov 13, 2018 | 12:23 AM
BigBlue2's Avatar
BigBlue2
Turn signal issue
The turn signal arm on my 86 F-250 stopped going into hold on - auto off after turn mode when trying to signal a right turn. Left turn still works normally. I can still signal right turn but have to hold it in position and it stops signaling as soon as I let go of the arm. Should also mention that I have the tilt steering option where the steering wheel angle can be changed by depressing the signal arm in the direction parallel with the steering column. Perhaps the turn signal issue is related to the tilt function?
If anyone has experience with trouble shooting the turn signal arm not going in to the hold mode and then auto release upon completion of the turn please let me know how you solved it. I haven't tried anything yet. Started doing it yesterday.
Thanks,
Big Blue 2
Old Nov 13, 2018 | 05:22 AM
kr98664's Avatar
kr98664
Sounds like the turn signal cam has failed. It is available as a separate piece. You don’t have to replace the entire switch:
Old Nov 16, 2018 | 10:41 PM
BigBlue2's Avatar
BigBlue2
It does seems the problem is with the switch or the cam. Replacement is probably needed. Thanks for the link to the youtube vid.
I did some research on replacement parts and the reviews on the replacement parts are pretty dismal, including the Dorman part referenced in the video.
Can anyone recommend decent replacement parts for the turn signal switch or cam?
Old Nov 17, 2018 | 01:55 AM
Ken Blythen's Avatar
Ken Blythen
I had the same 'hold it on one way' issue a few years ago with an '88 F150. Initially I tried the cam replacement approach, but it wasn't successful.........so I replaced the whole unit through RockAuto.
https://www.rockauto.com/en/catalog/ford,1986,f-250,5.8l+351cid+v8,1124019,electrical-switch+&+relay,turn+signal+switch,4832
The complication with a tilt column, is that it's necessary to remove the curved plug from the switch loom, thread the loom through the tilt mechanism, then re-attach the plug. There is a red wedge in the plug that comes out, releasing the bunch of wires attached; I would take a pic or draw a sketch of the wire positions.
With the non-tilt column, removing the plug isn't necessary.
Steering columns are such fun
Old Nov 18, 2018 | 01:13 PM
BigBlue2's Avatar
BigBlue2
Rock Auto shows three brands, one economy and two standard. Do you remember which one you used? Any advice on which one? I will choose one of the standard replacement switches. The most expensive one (Airtex) may use better solder and contact materials. Wondering which one to get. Definitely not getting the economy one. The reviews on that same model switch on Amazon are pretty dismal, "cheaply made" and even the "wire harness being short". No excuse for that! Looks like both the SMP and Airtex switches have a 3 year 36,000 mile warranty.
https://www.rockauto.com/en/moreinfo...939&cc=1124019
https://www.rockauto.com/en/moreinfo...551&cc=1124019
Old Nov 19, 2018 | 01:20 AM
Ken Blythen
I don't remember the brand, sorry.........it was probably 6-7 years ago.
I've had no problems with either Standard or Airtex products; but I avoid economy options, even in better brands.
Old Nov 19, 2018 | 08:12 PM
ctubutis's Avatar
ctubutis
You can still get a factory OEM variant.
Here's a post from Bill he made ~8 years ago; you might still be able to buy one at your local dealer, or Green Sales Company (1-800-543-4959) has 4 (I have no idea if those sponsors/sources he lists in that post are even still in business, I think Ed had a stroke and later died).
You want E5TZ-13341-B in red below:
The T/S flasher (D1FZ-13350-A / Motorcraft SF-552B) plugs into the fuse box.
It's round, about 3" long and has two prongs on it.
1980/83 F100/350 & Bronco: There are two different T/S switches:
E1HZ-13341-HA (replaced E1HZ-13341-K) .. T/S Switch-Use without Tilt Steering Wheel / Available from Ford.
MSRP: $87.00 // FTE sponsor PARTSGUYED.COM price: $62.64.
E1TZ-13341-D .. T/S Switch-Use with Tilt Steering Wheel / Obsolete / 16 available NOS.
1984 F150/350 & Bronco: There are two different T/S switches:
E4TZ-13341-A .. T/S Switch-Use without Tilt Steering Wheel / Obsolete / 26 available NOS.
E4TZ13341-B .. T/S Switch-Use with Tilt Steering Wheel / Obsolete/ 5 available NOS.
1985/86 F150/350 & Bronco: There are two different T/S switches:
E5TZ-13341-E .. T/S Switch-Use without Tilt Steering Wheel / Obsolete / 41 available NOS.
E5TZ-13341-B .. T/S Switch-Use with Tilt Steering Wheel / Available from Ford.
MSRP: $114.00 // PARTSGUYED.COM: $82.08.
Note: Some peeps are unaware that they have a tilt wheel, because...The tilt wheel is operated by the T/S handle-press it forward: BOING!
FordIowan
Nov 19, 2018 10:17 AM
tndallas
Dec 30, 2013 07:05 PM
saleen065
Aug 26, 2008 09:35 PM
buffystanley
Feb 25, 2006 07:32 PM
Culvert
Oct 8, 2004 11:17 PM
