Computer Chips & Tuners
tps
Old Sep 26, 2003 | 01:34 PM
muscletruck7379's Avatar
muscletruck7379
tps
what is the correct method for checking the tps I have the multimeter and I understand that its supposed to be .99 volts but where do i hook up the wires for the tester, what do I set the tester on and so-forth. its on a 91 e-150 w/351w
Old Sep 30, 2003 | 10:49 PM
FTE Ken's Avatar
FTE Ken
Connect the meter to the center wire and turn on the key. Then ground the other meter probe. At closed throttle you should see just under 1 volt. Please the throttle slowly and you should see a smooth transition to 4+ volts at wide open throttle. If not, then it needs replacing.
Old Oct 1, 2003 | 06:22 PM
muscletruck7379
center wire? theres only two.
Old Oct 1, 2003 | 08:26 PM
FTE Ken's Avatar
FTE Ken
Should be one on the outer side and one in the center.
Old Oct 3, 2003 | 09:24 AM
1990Fordf150v8's Avatar
1990Fordf150v8
I think my tps in my truck is going, where would i find it? I have a 1990 F-150 XLT X-cab 2x4 302EFI auto.
bigTEE56
29
May 24, 2013 06:42 PM
Bossman77
Jan 9, 2011 07:49 PM
richdawg
Sep 16, 2010 06:14 PM
bluefishgary
Feb 11, 2007 11:39 PM
sharlo
1978 - 1996 Big Bronco
Jun 12, 2000 09:06 AM
