Sponsored by: Auxito
Headlight adjust tool
Old Nov 11, 2018 | 06:54 PM
rickthefix's Avatar
rickthefix
Anyone have a cheap alternative for the a tool to adjust the headlights?
I found one for about $20, but would like a cheaper option for the one time use.
Old Nov 12, 2018 | 10:04 AM
alloro's Avatar
alloro
You can't really go cheap with that tool because cheap ones will round off your adjuster and cost you a lot more cash and aggravation. You can get it on eBay for $15.49 with free shipping.
https://www.ebay.com/itm/LISLE-14540...d/253969628090
Old Feb 8, 2019 | 11:48 PM
mako5972's Avatar
mako5972
You can aim your headlights at night by aiming your truck at a wall about 30 to 40 feet away. Aim left light toward the right and slightly down and the right light should be straight. It's cheap and it works.
Old Feb 9, 2019 | 05:57 AM
mudbug85603's Avatar
mudbug85603
The correct way to aim headlights so they don't aggravate or blind on coming vehicles is written in this article
https://www.popularmechanics.com/car...adjust-lights/
Old Feb 9, 2019 | 08:53 AM
blue&white's Avatar
blue&white
Headlight tool
i got the headlight tool of amazon. 13 bucks. It is solid metal construction. Works great on my 01 screw.
Old Feb 16, 2019 | 10:12 PM
blupupher's Avatar
blupupher
Yup, I got a $14 one off e-bay years ago, used it on my truck a few times (I swapped to a HID Retrofit), and have used it on 3 other Fords.
I have not touched it in probably 4 years, but have it if I ever need it again.
Old Feb 27, 2019 | 11:28 PM
V10man's Avatar
V10man
I used a 1/4: drive air ratchet with either a 5mm or 5.5mm socket. It's tight but doable.
Old Mar 4, 2019 | 03:26 PM
IndySilverAnny's Avatar
IndySilverAnny
I tried doing mine with a regular ratchet and socket, a socket on a 1/4" breaker bar, and a couple other hokey ways...
Ended up buying the correct Lisle tool off Amazon, and had my lights adjusted in a just few minutes.
My saved time was well worth a few bucks.
Old Mar 7, 2019 | 12:21 PM
paker's Avatar
paker
Buying a tool that has only one function especially for one time use is a waste. Unfortunately AutoZone or Advance Auto Parts don't carry this tool on loaner tool list.
Old Mar 7, 2019 | 01:40 PM
IndySilverAnny
It's a $12 tool. Spend $12 and have the job done in a few minutes, or fight for a couple hours using the wrong tool...
You're choice.
Granted, some trucks may have more room to work, but on mine, there was no way any other tool was going to do the job.
It was either this, or take the light out, adjust it, put it back in, repeat...
MrBonez
Modular V8 (4.6L, 5.4L)
Apr 3, 2017 07:29 PM
abe
Nov 13, 2005 02:51 AM
Offroadingman
1997 - 2003 F150
Mar 9, 2005 09:45 PM
Uncle Ferd
1997 - 2003 F150
Sep 15, 2003 10:39 PM
rfluitsma
Aug 19, 2003 09:08 PM
