no pipe after muffler?
Old Sep 26, 2003 | 01:03 PM
farmF-150's Avatar
farmF-150
I have an 86 F-150 with a 302 FI. I recently had muffler shop install a single in/out flowmaster 40 series muffler (with the exit behind the rear tire). This combo did not give me the exhuast tone I was expecting (deep/rumble).
If I cut the tail pipe off and run a short turn down pipe out of the back of the muffler, will this make it louder/deeper. Will it sound good? Will it cause any power/torque loss.
Thanks for the help!!
Old Sep 26, 2003 | 02:53 PM
akford351's Avatar
akford351
Turndown after the muffler will make it louder and deeper but will also make it louder in the cab as well. Should sound good tho.
Old Sep 26, 2003 | 03:35 PM
farmF-150's Avatar
farmF-150
Thanks for the help! I was actually thinking about leaving the pipe all the way to the rear axle then running a turn down. That way there wouldn't be lot's of noise in the cab.
Bascially cut the corner piece (around the rear tire) off and turn it down. Will this make any difference for sound/power?
Thanks
Old Sep 26, 2003 | 04:08 PM
akford351's Avatar
akford351
Maybe a lil' bit... You might wanna just put like a 4" exhaust tip on the end of the current tailpipe. With my exhaust tip I notice more rumble and a deeper note than without one. Also looks good to boot.
Old Oct 18, 2003 | 02:47 AM
fordbeast_80's Avatar
fordbeast_80
If you still have your cats that is why it isnt as loud as you would like the best sound with cats is a straight pipe IMHO
Old Oct 19, 2003 | 09:17 PM
77hiboyboy's Avatar
77hiboyboy
With flowmasters the best luck I have had with sound is with a big 4 inch tip (3.5 or bigger) to get a decent tone, with turndowns, or anything else they sound like a giant vacumn cleaner IMHO.
Old Oct 20, 2003 | 08:28 AM
farmF-150's Avatar
farmF-150
Thanks That is probably what I will do. I just can't figure out why my flowmaster 40 series sounds very close to a stock muffler! It is very quiet and sounds very weak
I thought dumping the cats would help but still no difference? I have taken off the smog pump belt and still no difference?
Which one would work better: a 4" slash cut tip or a 4" MEG tip from jegs(which looks like a megaphone)?
Thanks and let me know what you think.
Old Oct 21, 2003 | 10:55 AM
seans64''s Avatar
seans64'
just dump it out of the flows..
edreckers
Aug 11, 2015 04:13 AM
HogTied
2004 - 2008 F150
May 15, 2011 09:11 AM
pamelbert
6.4L Power Stroke Diesel
Feb 27, 2008 07:13 PM
mtfrdlvr
Exhaust Systems
Dec 4, 2007 02:29 AM
sleddog
Exhaust Systems
Nov 3, 2004 11:11 PM
