Piecing Together E99 Conversion to L99
Old Nov 10, 2018 | 10:08 PM
socal_pzy's Avatar
socal_pzy
Warning: This is a 2-3 year Project
Hey guys,
Im going to try to piece together the RiffRaff Conversion kit, but try to save money where I can.
I was wondering if you guys can confirm if im missing anything.
Short List Reasons for the Conversion:
- E99 Up-pipes have a leak
- Some small oil coming from the OEM pedestal (found after washing engine bay).
- Turbo life could be degraded with an exposed air intake box. Confirmed with my grandfather its been that way for "awhile". Air box already replaced.
- Live in California, anything that doesn't resemble stock gets flagged during Smog.
- Horsepower goals are only 400hp
- Daily Driver only, but Tow once a year
- E99 Conversion with individual part purchase, is potentially cheaper then T4 and RiffRaff Kit
- I can work on installing HPX and FRx at the same time everything on top is taken apart.
If im not mistaken, I can save money by buying:
- Ford Stock Intake Plenums Manifold (should be strong enough for 400hp)
- larger market for 99.5 Bellowed Up-Pipes (RiffRaff International are pretty expensive)
Purchasing the other individual parts from RiffRaff
Garret Non-EBPV/Blank Pedestal 99.5 - $124
https://www.riffraffdiesel.com/garre...estal-99-5-03/
Garrett GTP38 High Flow Outlet - $79
https://www.riffraffdiesel.com/garre...h-flow-outlet/
Garrett Compressor Housing Outlet O-Ring 99.5 $5
https://www.riffraffdiesel.com/garre...-ring-99-5-03/
Turbo Compressor Housing Outlet V-Band Clamp 99.5 $8
https://www.riffraffdiesel.com/turbo...clamp-99-5-03/
Complete CAC IC Boot Kit 99.5 (3.25” or 3”) $128
https://www.riffraffdiesel.com/compl...oot-kit-99-03/
Stainless Steel T-Bolt Boot Clamps (3.25” or 3.5”) $4
https://www.riffraffdiesel.com/stain...t-boot-clamps/
Turbo Pedestal Bolt Kit 99.5 $10
https://www.riffraffdiesel.com/turbo...t-kit-99-5-03/
Turbo Re-Install Kit $11
https://www.riffraffdiesel.com/turbo...all-kit-99-03/
Boost Gauge Parts:
AIH Delete Tapped Plug $11
AIH Mechanical Boost Tube $5
Air Intake Heater Plug Code Eliminator $13
RiffRaff Conversion Kit for reference
https://www.riffraffdiesel.com/riffr...onversion-kit/
Thanks guys for your time.
Update on Parts I've Gathered so far (all parts are from 99.5 + 7.3): I'll give a Price Sheet once this is built
- Sypder Intake (thanks to Sous)
- Stock Intake Plenums (thanks to HD Rider)
- Ebay Bellowed up pipes
Old Nov 11, 2018 | 12:28 AM
duck fan's Avatar
duck fan
Because racetruck
Originally Posted by socal_pzy
Hey guys,
- L99 Sypder Intake Manifold (ebay)
- Rebuilt GTP38R (local CL)
Ford Intake Plenum Manifold Cover 99.5 $136
https://www.riffraffdiesel.com/intak...cover-99-5-03/
Boost Gauge Parts:
Looks good, I would just get this pedestal instead and save $30.
https://www.riffraffdiesel.com/riffr...estal-99-5-03/
Old Nov 12, 2018 | 04:58 PM
beef tits's Avatar
beef tits
If anyone is selling a "rebuilt" GPT38R, I have a feeling they don't have a clue what they are talking about.
The GTP38R likely costs more to rebuild than get a new one, and I sure would not be buying a ceramic ball bearing turbo on craigslist. The stock turbo is a completely different story and can be rebuilt pretty cheaply.
Old Nov 12, 2018 | 05:54 PM
HD Rider's Avatar
HD Rider
Hey guys,
Boost Gauge Parts:
IvI' got intake plenums you can have. Pm a shipping address and I'll send them out.
Old Nov 12, 2018 | 06:40 PM
Bonanza35's Avatar
Bonanza35
HD Rider will get you started. Go to the salvage yard and pick everything up pretty cheap. I don't see any 38R turbo's out there rebuild. They have to go back to the factory to be done right. Stock late model yes. But change the wheel, like Clay's 4x4 wheel and you will be golden.
Old Nov 12, 2018 | 06:43 PM
Bonanza35's Avatar
Bonanza35
HD Rider has got you started. Go to the salvage yard and pick up the rest cheap. But I don't see any 38R turbo's out there rebuilt cheap. They have to go back to the factory to be done right. Stock turbo's yes. But put a different wheel in it like Clays 4x4 and you will be golden.
Old Nov 12, 2018 | 06:44 PM
Bonanza35's Avatar
Bonanza35
Sorry, I lost the first one I thought. And my post came up twice.
Old Nov 12, 2018 | 11:06 PM
HD Rider's Avatar
HD Rider
Hey guys,
Boost Gauge Parts:
I've got intake plenums you can have. PM a shipping address and I'll send them to you.
Old Nov 12, 2018 | 11:09 PM
HD Rider's Avatar
HD Rider
Sorry for the double post.
Old Nov 13, 2018 | 12:00 AM
socal_pzy's Avatar
socal_pzy
PM sent. This means a lot. Thank you.
Old Nov 14, 2018 | 05:12 PM
socal_pzy's Avatar
socal_pzy
Just curious what you guys think of this Super Cheap Bellowed Up-Pipes?
Amazon Bellowed Up Pipes Amazon Bellowed Up Pipes
A few people reviewed them already this year. Not expecting an easy install, but...
With the Money saved, I could find a shop to ceramic them for extra protection long term.
Old Nov 14, 2018 | 05:22 PM
Walleye Hunter's Avatar
Walleye Hunter
What do you think? 'Super cheap' scares me away from everything. In spite of all that verbiage I see two important words missing....stainless steel. At that price what do you expect?
Old Nov 14, 2018 | 05:26 PM
Colorado350's Avatar
Colorado350
Your signature says E99, the Amazon link says 99-03…my guess is they’re L99. I would spend the $400 on Clay’s Bellowed that you KNOW fit, skip the ceramic and wrap them with exhaust wrap and metal zip ties. If you coat them and they don’t fit now you’re out $100…plus your time dicking around with cheap Chinese crap. My .02
Old Nov 14, 2018 | 06:40 PM
socal_pzy's Avatar
socal_pzy
Im converting to L99 so I believe these will be the right fit. May not be the best product... but should fit for the conversion.
Old Nov 15, 2018 | 06:41 AM
Dan V's Avatar
Dan V
I just installed a T4 on my '01.....so I have some Dorman uppies, a modded stock turbo with DieselSite WW2 (rebuild with a 360 bearing) and a delete pedestal. PM me if you are interested.
