Missing belts and engine components
Old Nov 14, 2018 | 07:51 PM
FuzzFace2's Avatar
FuzzFace2
Originally Posted by SynDave
I want to restore it but as of now it doesnt turn over. It's missing some belts as you can see. Not to mention it's in rough shape
It looks like you are only missing the air pump belt and you don't need it to get it running.
Does the motor turn over by hand but will not with a fully charged battery?
If yes to both then either change all the battery cables or pull them and clean the ends& where they bolt down at.
Once running do worry on how bad it my run if compression and carb is good as it may be the feed back system the truck was built with.
This is known to have issues if not fully working as it goes into limp mode. There are post on converting to non-feed back system.
Dave ----
Old Nov 15, 2018 | 06:17 PM
jackietreehorn's Avatar
jackietreehorn
thank you so much for the information. Is there a repair manual I can purchase some where to help me learn and guide me?
Hayne's Manual for 1980 ford trucks. There is also a CD of the orig factory service manual on ebay
bill777
Dec 2, 2007 06:11 PM
inline 6
Jul 5, 2005 03:07 PM
Brians1966
15
Dec 31, 2003 07:54 PM
