Does anyone make / sell a front stock bumper with cut outs for driving lights?
I see LMC has them for the 73-79 trucks Truck Parts and Truck Accessories
But have not found anyone that has them for the 80-86 trucks.
You can buy new stock replacements either painted & chrome and that's it that I can find.
I am not looking to add one of them big ugly winch / off road bumpers or a grille guard just to add lights.
I also don't want to add them hanging under the bumper either.
In the bumper they kind of blend in and look like they belong there.
I have also been looking at different square driving lights, I don't think round would look right with the square head lights, that I may be able to add to the bumper if I cut the holes so that could be an option too.
Thing is they would need to fit in the recess that runs across the bumper where the rubber strip? runs.
Dave ----
So I guess this is like a unicorn, never to be seen?
Guess I will need to look into making my own custom bumper for my custom F100 flare side.
Dave - - - -
I have not started this yet, still have to do a little more body work and paint but was thinking if there was a Vender that had them and price not not o would go that route.
Just a quick look, measurement it looks like the area I could mount the lights was ruffly 3" high buy 8" wide with bumper on the ground.
I needed that so I know what size driving lights I should look at.
This may be a winter project when too cold to paint and why I am asking now.
Dave - - - -
I found this yellow truck way back in the day and honestly don’t mind the round lights! I’ll be after something similar as seen in my rendering, I figure a 3” round light. Definitely going to be custom though! I’d also like to tuck the sides of the bumper in a little more and will use studs to mount the bumper from behind for the clean flush look.
Thanks for the pictures will check them better on my pc.
I also going to do the studs from behind so the bumper is floating both front & rear like they did in the fifties.
I don't want to paint the bumpers so going to look into chrome wrapping them when the time comes.
Thanks again
Dave - - - -
If you don't want the bumpers to be painted or sprayed with bedliner you might consider powder coating. You can get equipment to DIY, or you can find a local business that can do it.
I did not want some big ugly bumper hanging off the front, not even a grill guard, I like the clean line of it stock.
As for powder coat the chrome looks more like nickel as I have something done in it.
Unless you have a LARGE oven I can't see anyone doing bumpers at home.
I also don't want painted body color and bed liner belongs in the bed or cab floor not on the body or bumpers.
I don't know if anyone around here does the spray chrome but hear it's not cheap.
YouTube has someone wrapping a Chevy 55 bumper, the truck bumper does not have all them curves.
Dave - - - -
Dave, the bumper build article I linked at least has a good idea for adding light pods. Have you considered modding an OE bumper?
Now that I am on my PC the round lights don't look that bad. I know the 73-79 bumper you can get (LMC) with round & rectangle lights I just don't know the size on either, may have to call to find out.
I will also check out the link at the light pods now that I am on a PC. It is hardtop check out links & pictures on my phone.
As for the OE bumper I was going to use 1 of the 2 (bent) ones I have. I will straighten both first then after I have the lights I will use, I will cut the hole and do what I need to for mounting them.
I am thinking I will need a tab or 2 for mounting
Thanks
Dave ----
