1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2011 Ford F-550
Old 11-09-2018, 06:04 PM
GR8TSCT's Avatar
GR8TSCT
GR8TSCT is offline
Talking 2011 Ford F-550
Hello, I am the onsite mechanic at a retirement community. We have a bus that is a 2011 Ford F-550 with the V-10 gas engine Chassis. There is a problem I am having with the blending door for the heater. It doesn't get as hot as it should, and only hot at idle speed. When you increase the RPM's it goes cold. The higher you go the colder it gets. When you bring it back to idle it is warm again, however not hot like it should be. Do this year Ford use vacuum to control the blending door? Does anyone have any idea what it might be? I have only seen that in Chevy's back in the early 2000 that used vacuum to control the blending door.
Old 11-10-2018, 11:47 AM
seville009's Avatar
seville009
seville009 is offline
Don’t know if this will help you; if not, that’s all I’ve got.....
it from the “how to” section of this forum
https://www.ford-trucks.com/how-tos/...ctuator-361641
sftbalnerd
09-20-2017 04:23 PM
smokem331
01-17-2013 11:37 AM
jrod46256
11-19-2008 10:19 AM
jdew1920
09-25-2006 07:45 AM
brian931
1983 - 2012 Ranger & B-Series
03-02-2006 03:10 PM
Quick Reply: 2011 Ford F-550
