GP push button mod?
Old Nov 8, 2018 | 11:01 AM
jayro88's Avatar
jayro88
GP push button mod?
So in preparing for winter I am going through my GP's and replacing any that are needed. My WTS light isn't staying on as long as it should (about half as long), so am thinking I have a plug or two burned out. If not I an thinking I will just switch it to a manual push button so I don't have to worry about the controller etc.
If I remember right it is as simple as running a wire from one of the controller posts through a push button to ground. Is that correct? If so, which one?
I did a search, but didn't come across a thread that specifically lays it out.....although it could be that I just search right. Thanks
Old Nov 8, 2018 | 12:25 PM
PlumCrazy7's Avatar
PlumCrazy7
I decided that using power to trigger the solenoid was better, if it runs through the fuse pops instead of triggering the solenoid and burning up plugs.
I ran a ground wire to the intake, ran power through a switch from the fuse panel.
Edit: if you trigger it by ground you have to run a supply wire as well.
Old Nov 8, 2018 | 01:18 PM
jayro88's Avatar
jayro88
I was looking around and found the pic below. In the tread it said all I have to do is add a push button to ground the post with the white wire.
Also, with your setup you are just manually sending a small 12v signal through the switch to the controller relay to tell it to close? Is this in case the push button shorts/grounds out it won't constantly run the plugs because it will blow the fuse first, correct?
As far as running a power source for the 12v trigger side of the relay, couldn't you just leave it as is and it should get power when the key is turned to the on position?
Maybe i am just really confused.........
Old Nov 8, 2018 | 01:25 PM
Charmalu's Avatar
Charmalu
https://www.ford-trucks.com/forums/7...low-plugs.html
Dave Sponaugle explains how to do the early style 83 - 87 and the later style 88 - 94
https://www.ford-trucks.com/forums/5...low-plugs.html
Charlie
PlumCrazy7's Avatar
PlumCrazy7
​12v to the solenoid, my controller was toast so I removed all the wiring for it to clean up the area.
I believe you are correct that you could just ground it. I forgot that the controller grounded the solenoid to trigger it.
Old Nov 8, 2018 | 01:37 PM
jayro88's Avatar
jayro88
Thanks guys!!!
I swear I did a search for the topic and didn't find the threads you linked.......
Old Nov 8, 2018 | 04:43 PM
Charmalu's Avatar
Charmalu
You need a few more links? :
I usually go to Google and type in what Iam looking for, then hit the "images" button and this comes up.
https://www.google.com/search?q=manu...w=1093&bih=521
Or if you want results for this forum, "site ford-trucks.com manual glow plug switch". or something like that.
https://www.google.com/search?q=site+ford-trucks.com,+manual+glow+plug+switch&source=lnms&tb m=isch&sa=X&ved=0ahUKEwj3yu2b78XeAhVHHzQIHUp-AQ_AUIEygC&biw=1093&bih=521
Charlie
Old Nov 8, 2018 | 05:00 PM
jayro88's Avatar
jayro88
Thanks, I appreciate it.
oldbird1965
Jan 19, 2016 12:04 PM
Meg719
Jul 14, 2015 07:23 AM
Eallend7
Dec 23, 2012 09:28 PM
wmiller
Oct 27, 2007 02:25 PM
mydieselpower86
Jan 29, 2006 10:45 PM
