Manual GP switch
Old Oct 26, 2007 | 09:00 AM
wmiller's Avatar
wmiller
Manual GP switch
The glow plug driver in my truck is fried and need to put in a manual push button. What wire do I need to use for this?
Old Oct 26, 2007 | 09:52 AM
Cuda_jim's Avatar
Cuda_jim
There is no GP driver. It's controlled by the PCM...it completes a ground circuit. It's the small wire on the GPR, Purple w/orange stripe.
The small red w/light green wire is B+ with the key set to start or run.
Remove the small purple wire. Attach it to one side of the button. Attach the other side of the button to a ground.
This will only work if your GPR is good.
Old Oct 26, 2007 | 09:55 AM
wmiller's Avatar
wmiller
Should I fuse the button or are the glow plugs allready fused?
Old Oct 26, 2007 | 09:57 AM
Cuda_jim's Avatar
Cuda_jim
Already fused. #22 under the hood.
Old Oct 27, 2007 | 02:25 PM
wmiller's Avatar
wmiller
do i hook the purle wire to the button or do i run a new wire from botton to where post on reley where purple wire was?
