Blinking OD Light E40D
Old Nov 7, 2018 | 12:12 PM
4CFarms's Avatar
4CFarms
Just recently I've been having an issue with my OD light blinking and throwing me out of OD when I'm cruising down the highway. When it does this and I come to a stop, its almost like it failed to downshift or the shift points are just all messed up... If you turn the key off and restart, everything is fine. And then today, when I was driving through town, the TC started slipping and I lost all power, but if I shifted into "2" manually, it would drive just fine. This case, there was no OD light blinking.
Has anyone ever heard of anything like this? I've had it scanned at the parts stores and they couldn't read any code. Does anyone suggest a scanner that can also read tranny codes? Any help would be appreciated. I'm leaning towards something electrical, but an not sure yet.
Thank you!
Old Nov 7, 2018 | 12:36 PM
7.3 forever's Avatar
7.3 forever
A great scanner to have is autoengunuity great deal for the money and will possibly save you money in the future.
Old Nov 7, 2018 | 03:55 PM
fordpride's Avatar
fordpride
On the cheap side, you should be able to find a superchip 1705 really cheap which will read engine and trans codes.
Old Nov 7, 2018 | 04:18 PM
4CFarms's Avatar
4CFarms
Will one of the cheap ones from amazon read the trans codes? I know they do ok with CEL ones, but haven't found one yet that will help with my trans codes.
Old Nov 12, 2018 | 09:02 AM
fordpride's Avatar
fordpride
No they will not.
Old Nov 15, 2018 | 09:47 AM
Talyn's Avatar
Talyn
Is the speed gauge jumping around? If yes, might need to clean VSS on the rear differential or replace. It will cause this issue.
There is also a sensor on the trans that will cause this issue.
Codes will better tell you what is wrong though and is the best way to go if all possible.
Old Nov 17, 2018 | 04:22 PM
Action4478's Avatar
Action4478
Have you ever heard of anyone cleaning the VSS & had it fix a problem ?
This poster most likely has a wiring issue . Shutting off the key most likely doesn't clean the VSS temporarily
Old Nov 18, 2018 | 09:14 PM
Talyn's Avatar
Talyn
If its got metal on it flakes, then yeah, it could fix the issue.
I did specify "or" replace.
Old Nov 19, 2018 | 08:23 PM
Action4478's Avatar
Action4478
Again , have you ever heard anyone fixing this issue due to :Flakes: ? Flakes do not come and go .
What the hell do I know .
Old Nov 19, 2018 | 11:15 PM
Talyn's Avatar
Talyn
I know if you get some stuck on the sensor, it wont read right. And I guess they can cause bad shifts on an auto.
Differentials dont have filters in them, they have galleys for the .... extra's to fall into. Sometimes they make it to a magnet and stick there.
But depending on how much you got in there, you're damn right, could be a far worse issue. I've found some sorta metal flake in the little galley on every rear end i've opened. Granted, you've worked on far more than me, but when i'm 15/15 on this. I just believe it at this point. But I"m talking a few little flakes, not more than that.
Old Nov 20, 2018 | 09:31 PM
Action4478's Avatar
Action4478
If there s **** on the sensor , it will always be on the sensor
RÖENTGEEP
Mar 23, 2018 01:49 PM
85F250Diesel
Jul 26, 2017 06:44 AM
lance65
36
Jun 9, 2016 11:03 PM
E450 newbie
Dec 18, 2015 05:40 PM
reitman
16
Sep 26, 2007 01:23 PM
