I have a 95 7.3 that needs injector work. I have access to some injectors from a 2003 with 220klms on them Good idea???Would I gain anything Thanks for the help in advance Terry
Your injectors are AA code(90cc single shots). The 03 injectors are AD code (140cc split shots).
They technically will work but you will need tuning to run the correctly.
I wouldn’t personally run them. I would have mine rebuilt by Jim at Rosewood diesel.
If you are going to get new injectors why not upgrade them? It is a little more of an expense and depending on how big you go you will need to upgrade your HPOP. You will see a big difference.
Not true, you dont' necessarily need to upgrade your HPOP to run larger injectors.
Tell me about it Glenn, after installing the spare 15° HPOP in place of my t500 i keep getting the 1211 on a WOT run or towing the dump trailer. I still havent gotten around on checking for my HPOP drain problem either.
