6.2L V8 Discuss the 6.2L V8
2014 6.2 code
Old Nov 3, 2018 | 12:17 PM
louis584's Avatar
louis584
4wd Low
2014 6.2 code
what is code po6b6 on a 6.2 engine?
Old Nov 3, 2018 | 12:46 PM
tjc transport's Avatar
tjc transport
i ain't rite
knock sensor code.
Old Nov 3, 2018 | 12:49 PM
kry226's Avatar
kry226
Looks like it's a knock sensor code.
https://www.obd-codes.com/p06b6
When a code P06B6 is stored, it means that the powertrain control module (PCM) has detected an internal processor performance error with a certain knock sensor (designated 1) circuit. Other controllers may also detect an internal PCM performance error (with the knock sensor circuit) and cause a P06B6 to be stored.
EDIT: Also looks like I was posting at the same time.
Old Nov 3, 2018 | 12:52 PM
tjc transport
i ain't rite
mehhh. more eyes posting just confirms the diagnosis......................................... . as long as we post the same thing.
Old Jun 24, 2019 | 10:41 AM
louis584's Avatar
louis584
4wd Low
Update on code p06b6. I checked the engine compartment with it running. Found 1 spark plug boot on #3 cylinder arc against the block. Changed the boot and it seems to correct my problem.
SPODEBOY
Mar 30, 2006 06:54 PM
jtharvey
19
Jan 4, 2006 03:56 PM
Slider28
Bronco II
Mar 23, 2002 08:51 PM
