I installed Wide Open Performance's QSB turbo. I now get this code. I replace the sensor and I still get the code. I called them and they told me it had to be the sensor.
However, it still spits this code. It happens only upon start up. Once I clear it it will never come back on until I start it again. Can I disable this or anyone have any more advice? Thanks a bunch guys!.
97 7.3
If you install the blackcloud code eliminater it will eliminate that code but then it will throw a code that says something like low voltage at that sensor.
That doesn't sound good. I posted that particular link because BCDP is a sponsor. I don't have any actual experience with it.
The exhaust backpressure code eliminator that I use is from SP-diesel. They were the only company that marketed such a device back when I needed it. It's been nearly three years since I've had a P047x code. No related codes either.
