2018 4 wheel drive stuck
Old Nov 6, 2018 | 11:18 AM
  #31
00t444e's Avatar
00t444e
I am surprised your having problems with the esof 4x4 (not really), according to some people on here the esof system never has any problems. Manual 4x4 FTW.
Old Nov 6, 2018 | 01:38 PM
  #32
troverman's Avatar
troverman
My buddy has a '97 F250 old body style. Classy truck in many ways. His truck is obviously manual hubs / manual shifter. Two winters ago the linkage between the manual lever and the transfer case rusted out and broke when he tried to engage 4x4. That's a problem ESOF will never encounter, so let's not pretend it's impossible to have a problem with the manual setup. Not to mention on the newer trucks there is an electric solenoid that prevents you from shifting into 4-low when the truck is not in neutral...something else than can fail which never will on the ESOF.
Old Nov 6, 2018 | 01:59 PM
  #33
00t444e's Avatar
00t444e
If the linkage breaks you can still engage it manually with some pliers, and you are supposed to be in neutral to shift into low range on either system.
Old Nov 6, 2018 | 02:02 PM
  #34
troverman's Avatar
troverman
Yep, those linkages seize up pretty good. Pliers won't help at that point. I agree you need to be in neutral to shift to low in either system...but the electronic system does not use an inhibit solenoid, because it doesn't need to. If you aren't in neutral, it simply won't allow the transfer case to shift until that condition is met.
Old Nov 6, 2018 | 02:05 PM
  #35
00t444e's Avatar
00t444e
You can use pliers to turn the ear on the transfer itself not the linkage, you can actually do that on an electric shift too if the motor fails, but you have to unplug and unbolt the motor to get to it.
Old Nov 6, 2018 | 02:07 PM
  #36
troverman's Avatar
troverman
Yes, I am aware of that. But sometimes the little ear won't budge itself without a lot of force...the factory shift lever gives more leverage than pliers...and this is what can cause the rusted up connection to break. It is harder to try to manually shift the ESOF systems. Possible, but you need to know where the indexing locations are.
Old Nov 6, 2018 | 03:35 PM
  #37
H-D Dad's Avatar
H-D Dad
Thanks for all the replies. Found the vacuum line off on right front hub. I found a nice little ditch by the house to play, I mean to test the system. All works fine.
Old Nov 6, 2018 | 04:12 PM
  #38
Busa 1 Dave's Avatar
Busa 1 Dave
Originally Posted by KCRebel
When you say no go do you mean it wouldn't go into 4 lo? I've had mine in both 4 hi and 4 lo and I've never touched the hubs. It isn't necessary. Something else is amiss here. 4hi can be switched on the fly. 4lo requires stopping and shifting to neutral. Could be your rear tire was still spinning if it was freely turning. That would prevent the engagement of 4lo. Regardless the locking of the hubs was unnecessary as the hubs are more like curb feelers and fake cell phone antennas for the nostalgic guys who think they are still necessary. I've had 4wd trucks like this for 20 plus years and never had a single issue.
Agree--shifted my 18 in and out last weekend many times. I cannot get out to lock mine if I wanted to. Center cap on the wheels. Works every time I need it to which is often as much rain as we have had! Sank the drivers (on a ranch road between 2 fields) side then got out to survey and it kept sinking on the drivers side. Barely able to open the door enough to get back in. Had to get the big row crop Deere fired up to pull it out!
Old Nov 6, 2018 | 05:37 PM
  #39
00t444e's Avatar
00t444e
How was locking the hubs not necessary? He had a loose vacuum line which didn't allow the hubs to auto engage, locking the hubs manually bypasses the vacuum system so you can still lock the hubs. If he hadn't of locked the hubs he would not have gotten out.
Bobcanada
Oct 28, 2019 05:05 PM
MPawelek
6.7L Power Stroke Diesel
May 13, 2018 05:14 PM
Americal_Vet
Feb 22, 2017 04:45 PM
Duck Hunter81
Dec 22, 2009 07:05 PM
2000Mark
Aug 18, 2007 12:53 AM
