4X4 Auto / Lock
Old Feb 22, 2017 | 04:21 PM
Americal_Vet's Avatar
Americal_Vet
4X4 Auto / Lock
Hey Guys - Did a forum search but could not find an answer, so here goes.
I just picked up my new SD F350 SRW with FX4 pkg. It has the manual locking hubs, and ESOF (electronic shift on (the) fly)
My trade was an F150 FX4 with ESOF, and when I needed 4WD I just turned the ****. The manual locking hubs on this SD have "auto" or "lock", similar to a Jeep I had years ago.
So, my question is; Do I have to get out and turn the hub to "lock" each time I need 4WD and then use the ESOF ****, or can I just turn it to the "lock" position and leave it, then use the ESOF **** if necessary?
Old Feb 22, 2017 | 04:25 PM
fordmantpw's Avatar
fordmantpw
Turn the hubs to the "auto" position and leave them there. When you need 4x4, it will work just like your F150...just turn it to where you need it. The Super Duty just doesn't have the all wheel drive mode that the F150 does.
The "lock" position on the hubs is only there in the event of a failure of the vacuum system that automatically locks the front hubs. If that system fails, just put it in "lock" and then shift the transfer case with the **** like normal.
Old Feb 22, 2017 | 04:45 PM
Americal_Vet
Thank you sir, you've been a great help! The "owners" manual is a bit vague. - Best wishes!!
blake2182
May 5, 2011 03:16 PM
NStorm
6.7L Power Stroke Diesel
20
Jan 11, 2011 01:45 PM
Jake4809
6.4L Power Stroke Diesel
24
Apr 24, 2007 02:55 PM
Beamer2
Modular V10 (6.8l)
Jan 16, 2006 02:52 PM
cpd806
Oct 24, 2005 04:23 PM
