94' F150 - 5.0/E4OD. Strange Problem
Old Nov 3, 2018 | 10:14 AM
nomadw8's Avatar
nomadw8
I was backing a trailer up a dirt hill. Had to do a lot of back & forth & stop/starts to get it positioned. Anyway, at one point I went to re-start & after it started I could not move the shift lever out of park. I had to turn truck off, move the key to ON position & then move the shift lever to Neutral to get it started. Also when all this happened the ABS light came on and has stayed on.
Anyone have any clues as to what happened and what the fix is?
Thanks
Terry
Old Nov 3, 2018 | 11:50 AM
sandymane's Avatar
sandymane
If the truck is not starting in park and it is just your ABS light you need to clean or replace the ABS sensor located on top of your differential. There is one bolt that holds it in and then it just pulls out for cleaning or replacement. You may have to pry a little to get it started out. See if that does it and let us know.. I would clean it before replacing. If the truck is not starting in park now it is probably your neutral safety switch and we can tell you how to correct that also if needed. Sandy
Old Nov 3, 2018 | 08:04 PM
nomadw8's Avatar
nomadw8
I starts in Park but after it starts I can not move the shift lever out of park.
I now have to move the key to ON position, move the shift lever to Neutral, start it up & then shift to D or R.
Also the ABS light is now blinking.
Old Nov 3, 2018 | 08:08 PM
sandymane's Avatar
sandymane
The blinking ABS light is giving codes if blinking. When you can, count the number of pulses of the light and note if there are any pauses between the blinks.
Old Nov 3, 2018 | 09:58 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Usually when the shifter won't move out of park it's a problem with the brake light switch.
Old Nov 3, 2018 | 10:02 PM
sandymane's Avatar
sandymane
Yep, I was going to have him check the brake light fuse. first. #13 I think. And then the boo switch. If he comes back with 16 blinks it is probably the switch or fuse.
Old Nov 4, 2018 | 07:36 AM
nomadw8's Avatar
nomadw8
16 flashes then a pause .....repeated.
I checked fuse 13 (20 amp) - it was blown.
I'll replace today & hopefully that will be that.
Thanks to the group.
nomadw8
Nov 3, 2018 10:14 PM
60Joe
Aug 29, 2008 11:56 AM
97F150 4WD
1997 - 2003 F150
Jul 15, 2005 11:34 PM
betsycam
Jul 28, 2004 09:46 PM
