Sponsored by: Auxito
Blinking ABS Light
Old Jun 17, 2005 | 10:42 AM
97F150 4WD's Avatar
97F150 4WD
Question Blinking ABS Light
I have a problem- apparently something happened during the night. and this morning when I got up to go to work and started the truck, and went to shift into drive and it wouldn't shift I looked down and the ABS Light is flashing.
It flashes 16 times and then stops and recycles.
Any help would be greatly appreciated.
I already disconnected the battery cable and reconnected about 10 minutes later.
When I turn the key on even without starting the light starts to flash.
when I start the truck the light goes out like normal then comes back flashing.
Thanks in advance
97
Old Jul 15, 2005 | 11:34 PM
FORDandYAMAHA250's Avatar
FORDandYAMAHA250
Exact same thing is happening to me now, you find out what was the problem?
