Catastrophic Failure
Old Oct 30, 2018 | 03:02 PM
ms1780's Avatar
ms1780
I was pulling about 12k last week down a flat 4 lane highway. Truck only wanted to run about 60 on the +50 tune to keep egts around 1200 so that's what I ran. I went about 40 miles and took my exit. When the truck came to idle there was a horrible engine clatter and white smoke. I limped the truck to a shop just about a block up the road. They had AE and it scanned two bad injectors but it has a mix of oil and coolant running out of the driver's side manifold. They think it has a blown head gasket as well as several failed injectors. I have no reason to doubt them but I wanted to get some opinions from here. Would you replace the head gaskets and injectors or try to find an engine to swap? This truck has had issues since I got it a couple months ago. It's a dog and wouldn't pull 10k lbs for crap. The truck is 5 hours from me so diognosing it myself is not possible. Thanks for any advice.
Old Oct 30, 2018 | 03:45 PM
Dan V's Avatar
Dan V
Head gasket failure is rare on these engines.
Old Oct 30, 2018 | 05:13 PM
Walleye Hunter's Avatar
Walleye Hunter
Sorry to hear about all of that. What are you going to do, have it worked on out there or get it towed home? Either way this is going to be expensive.
Old Oct 30, 2018 | 05:33 PM
ms1780's Avatar
ms1780
I'm leaning toward having it fixed down there. Since it has a long flat bed and it's loaded it would cost about $1200 to get it home. Book hours are 18 to do head gaskets on a 99 7.3. Either way I'm in deep and it's not going to be cheap.
Old Oct 30, 2018 | 05:50 PM
Walleye Hunter
As stated above head gaskets are not a likely candidate. Not impossible, just unlikely. Since the truck is fairly new to you and never ran right I shudder at the thought of what you are going to find. Since one side is showing problems that makes that part easy and you'll find what you find once the head is off. I do not know if injector O rings or cracked cups would cause your symptoms.
And I would only mess with one side if the other one is not causing trouble.
Old Oct 30, 2018 | 05:59 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Perhaps post your location or where the truck is and someone might know of a good shop in the area.
Old Oct 30, 2018 | 06:11 PM
ms1780's Avatar
ms1780
The truck is near Walnut Ridge, AR. I'm pretty confident in the shop it's at, I just hate to spend much money. They are going to pull the injectors on the driver's side and check the injector cups for failure first.
Old Oct 30, 2018 | 06:14 PM
Walleye Hunter
Their approach is sensible, that is a good start.
Old Oct 30, 2018 | 06:26 PM
ms1780's Avatar
ms1780
When you pull up to the shop and both mechanics are driving 7.3's with over 300k it makes you feel a little better.
Old Oct 30, 2018 | 09:37 PM
timmyboy76's Avatar
timmyboy76
I believe you said that you have oil and water mixing discharging from the drivers side. Just so happens, the oil cooler is located in same location. Perhaps, it shot an oring and conclusion is what the shops seeing.
Old Oct 30, 2018 | 09:53 PM
Colorado350's Avatar
Colorado350
Absolutely. Best of luck brother!
Old Oct 30, 2018 | 10:29 PM
ms1780's Avatar
ms1780
That could certainly be possible. They're going to pressurize the coolant system late this week or early next week and find the culprit. Thanks for the info. I sure wish the truck was home so I could troubleshoot it but that's just not in the cards. Way too expensive to tow it.
Old Oct 31, 2018 | 05:28 PM
hydro man 17's Avatar
hydro man 17
I tend to agree with timmyboy. It is at least a good place to start looking and is not nearly as involved and expensive as an R&R of a head.
Old Nov 1, 2018 | 08:33 AM
Dan V's Avatar
Dan V
A compression check should give you some information as well.
Old Nov 6, 2018 | 06:35 PM
ms1780's Avatar
ms1780
They pulled the injectors out of the driver's side today. One of them was completely loose and the tip is totally black. They are going to put new injector cups in that side and replace the one injector and pressure check the coolant side again. I'm also having them check the fuel pressure u der load and the ebpv sensor and tube. I am willing to bet the prescreen on the in tank lift pump are full of crap and I have a fuel starvation issue when pulling.
