engine swap time
Old Oct 29, 2018 | 03:37 PM
weldworks54's Avatar
weldworks54
engine swap time
I’m gathering parts to begin a engine swap. On my 1968 f100. I will be pulling the factory 240 out of the trucks and installing a 1986 351w out of a E250.
the truck is a 3 speed on the column.
My question is: will my bellhousing and transmission work with the 351w? Will my clutch work with the new engine?
I understand from what I have researched and read.
I will need a flywheel because the 240 is internally balanced engines. Is the flywheel I need the same size diameter and tooth wise as my 240 flywheel with the added weights? I understand there are 2 different weighted flywheels a 28oz and I believe a 50 something oz. which one will I need?
will the van style oil pan work in the truck or will I need a rear sump oil pan?
Thanks in advance!
any other advise I will be glad to listen too.
Old Oct 29, 2018 | 03:53 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Will the van (Econoline) style oil pan work in the truck or will I need a rear sump oil pan?
All 1975/91 Econolines have a rear sump pan, regardless of what size the engine size is. 351W introduced in 1975 Econolines.
Old Oct 29, 2018 | 06:43 PM
weldworks54
Thanks for the reply.
Old Oct 30, 2018 | 05:53 PM
Red69's Avatar
Red69
You need engine perches from a truck that came with a small block. The transmission, clutch and bellhousing are fine, but you have to use a flywheel with the right imbalance for your 351. Most likely 11" with 28 oz imbalance.
The other problem is the 302 style headers won't clear the bell housing and the shorty style point right to the clutch bell crank. You probably need to use the stock 351 manifolds.
You can use the 240's radiator, but if it is a 2 row core take it to a radiator shop and have the 3 row core put in. Some 240's had the 3 row as a HD towing package and even if yours isn't the tanks are wide enough for the 3 row.
Old Nov 1, 2018 | 06:20 AM
weldworks54
thank you for the reply that the exact type of information I am looking for.
Old Nov 1, 2018 | 07:38 AM
Red69's Avatar
Red69
One other thing I remembered is the 240's throttle linkage will be on the wrong side for the V8 carb. If you can find a V8 throttle assembly it would be easier, but you can modify the 240's if needed. I think a lot of years will work maybe from 65-72 or even later.
Old Nov 1, 2018 | 06:16 PM
weldworks54
Thansk I knew about the linkage being different. I’ve found a truck I can get the v8 linkage off of.
Let me ask this question i had a older gentleman tell me. I could swap my 240 engine perches around and they would work on the v8.
Swap the Passenger side to driver side then swap the driver side to passenger side
Old Nov 1, 2018 | 09:04 PM
RichS2659's Avatar
RichS2659
Wrong on that. For an FE, you just slide the Six perches to the next hole. For a small block (302/351W, and 351M/400), you can use -79 302 and 77-79 351M/400 perches. Or you can buy new perches from Autofab.
Old Nov 3, 2018 | 12:07 PM
weldworks54
Thanks for the information.
I got a set of perches today but I’m now on the hunt for a gas pedal assembly. The one I was goin to get was broken when I got to it.
Old Nov 3, 2018 | 12:30 PM
NumberDummy
For a small block (302/351W, and 351M/400), you can use 1969-79 F100 & 1975/79 F150 302 and 1977-79 F100/350 2WD 351M/400 perches. Or you can buy new perches from Autofab.
Fixed it for you...
Old Nov 4, 2018 | 10:54 AM
weldworks54
you all probably knew this was coming. Lol. I have another question.
The 351w has a electronic ingnition that i would like to keep. It is a blue plug DURASPARK. I’ve looked over the sticky thread found some good diagrams in that post. I’m a little confused on where I need to make the connection to my truck from the DURASPARK box. to make sure I’m correct in my assumption.
the blue wire wire should go all the way to my ignition switch on the run side. The red with blue stripe should be routed to the start side of the ignition switch.
Where I am confused is coming off the ignition switch to the solenoid off the solenoid to the coil.
My truck will have wires going to the solenoid. Do I need to disconnect those and run new wires? The diagram also shows a 1.1ohm resistor will my truck have this or will I need to acquire one?
i have saved all the wiring harness I could off of the donor van. I had to cut the harness behind the plug I have marked with black in the picture.
where could I find a wiring diagram of a 68 ignition switch?
Old Nov 4, 2018 | 11:04 AM
weldworks54
weldworks54
Engine Swaps
Oct 31, 2018 05:48 PM
cbracing17
Engine Swaps
Sep 29, 2005 07:40 PM
miichael
Engine Swaps
Jul 28, 2005 09:43 PM
unctarheels01
Apr 13, 2003 12:27 AM
