USAA Purchase Coupon
Old Oct 29, 2018 | 10:22 AM
Philisophe's Avatar
Philisophe
Currently Ford is offering $ 250. Coupon Through Jan 1 On 250/350's
Through USAA
Not much bet it helps..Ford states you can "stack-use" this with other incentives
Just tossing it out there
Old Oct 29, 2018 | 11:59 AM
'18_F250_4x4's Avatar
'18_F250_4x4
FYI, only for NEW truck and only if purchased from a dealer that is sent to you through USAAs buyers service. You sign up for the service and USAA will send your contact info to 3 or 4 dealers who then send you links to their Offered trucks; the idea is to have completion for your purchase dollars. USAA also says there is a pre-negotiated discount price the dealer should send you.
Got to your local dealers website and get the VIN and prices and the "offer should beat the listed price.
Old Oct 29, 2018 | 12:06 PM
Philisophe's Avatar
Philisophe
Appreciate the clarifications
Old Oct 29, 2018 | 12:37 PM
'18_F250_4x4
Ur Welcome. It works; I just used USAA and another part of the offer is it also gets you a .5% reduction on the interest rate when the dealer gets all the paperwork submitted.
Old Oct 29, 2018 | 12:57 PM
JD'sBigredv10's Avatar
JD'sBigredv10
The $250 offer is valid even if you don't go through their buying service. I just printed out the coupon and there are no stipulations. It is available to all USAA members and is valid at any Ford dealer. Took less than a minute.
Old Oct 29, 2018 | 02:10 PM
Philisophe's Avatar
Philisophe
I thinks the current incentive as JD's Said is pretty simple.. Ford has offered much higher incentives in the past...
That being said..I do not think the sales rep had a clue... I called this Morning he acted like I shot his dog...
My SD will be here in a few days..I will communicate with Ford/USAA prior to the paperwork..There may be stronger Incintives In November.. we shall see
Old Oct 30, 2018 | 10:08 AM
Flyct's Avatar
Flyct
FTE Community Team
Yep, did this last month. I had ordered my F350 using X-Plan. After the truck arrived I mentioned that I may be financing through USAA. When I went t pick up the truck I found that the dealer on his own found and applied the $250 additional rebate.
I did not use USAA buying service.
Phx Raven
Sep 18, 2018 10:59 PM
BillRes2
Aug 17, 2018 04:41 PM
Bowstring
Feb 20, 2008 11:36 PM
caleb
Jun 23, 2007 10:05 PM
jake00
Car/truck Buying Advice
Apr 25, 2004 04:51 PM
