Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Pickup Bed Lifter
Old Sep 25, 2003 | 08:24 PM
dynamic's Avatar
dynamic
Pickup Bed Lifter
im looking for a tool i saw on trucks tv. it hooks up to an average cherry picker, and you can pull a complete pickup box off your truck all by your self!!! has any one seen this, ive seen this used on "trucks" but the web site doesnt list anything for it or a link to any site about it.
ive emailed the site, with no response.
has anyone looked into this?
does any one have one?
-All Caps edited by Admin-
Old Sep 25, 2003 | 11:09 PM
chuck641's Avatar
chuck641
i remember seeing that .. the same company had all kinds of lifts to hold just about every body part. it seems like they would be pretty easy to make. i just did a search and found this: http://www.northerntool.com/webapp/w...oductId=383267
Old Sep 26, 2003 | 12:11 AM
460f250's Avatar
460f250
I made one from 3 2x4's. Two go across the box (on edge), one in front of the inner fenders and the other behind (trimmed to fit under the top rail). The third is cut into 2 pieces about 18 - 24" long which are screwed a foot apart between the 2 which go across. You end up with an "H" shaped frame you can sling from if you wrap a cable or chain around the center of the "H". I assemble it once I get the cross pieces in or it won't fit. Works slick and cost less than 10 bucks.
Old Sep 26, 2003 | 09:35 AM
daveengelson's Avatar
daveengelson
You may want to check out the autobody toolmart. They have 1 in their catalog, expensive though. Listed for $300. Lot of auto body supplies, and other interesting stuff.
www.autobodytoolmart.com
Good luck,
dave
Old Sep 27, 2003 | 12:23 AM
BobJonesSpecial's Avatar
BobJonesSpecial
I made one out of 2 X 4's also similar to 460f250's. You kinda have to make it fit whatever style pickup box you're working on.
The tricky part was finding the balance point so the thing would lift straight up. I used a big 1/2" eye bolt and a huge washer to hook the chain to. I re-drilled the hole about 3-times before I found the exact balance point.
Good luck, and be safe.
BobJonesSpecial
biglee
1947 and Older Ford Trucks
27
Sep 12, 2008 12:00 PM
Spartans
Mar 26, 2008 12:14 PM
vanHoy
Sep 16, 2006 11:03 PM
seamax
18
Nov 14, 2000 10:30 PM
