What injectors are best for running with TS chip?
Don't bother with a TS chip, get a Hydra. The first time you have to pull it out to reburn it you will regret ever buying it in the first place. Hydra is far superior and tuners offer the same tunes for both.
Also, new injectors will make a big difference in how it runs but don't expect too much. Even with 800+ ft lbs of torque that big old motor still has to move 7,000+ lbs of steel sitting atop a farm tractor suspension.
The holes at the tips of injectors, 30% larger than stock, vs 80% 0 would give you better atomization, but slower to dump a full injector of fuel.
30% nozzles are just "ported" stock nozzles, 80% is a new nozzle that actually comes that size to begin with. Tune writers prefer 80% because they are consistent to tune for while 30% depends on who ported the nozzle so results can be inconsistent with the same tune on different trucks' injectors
As beef **** mentioned, it is very convenient to have something you can update in your driveway (Hydra, F6, etc.) to prevent any down time. Mine is my daily driver so I couldn't afford to have my truck down for a week every time I needed/wanted a revision to the current tunes loaded.
With a new setup there are always growing pains. Some setups take longer to sort out than others. I'm pretty happy with mine right now and it's been about 6 months to dial things in to an acceptable range. I've got about 14 tunes or so and I'll probably end up only using 3 or 4 on a regular basis. The rest might get used on a rare occasion or probably never again.
I've definitely gotten my money's worth out of it with all of the changes I've done (revisions, tune order, etc.) and not suffered any down time (again...my daily driver). If it was my weekend truck that I didn't drive every day I might have kept my 6 position chip. I'm not a racer or need a tune for every different driving situation. I was happy with 6 tunes before and I'll end up with less than that for how many I use now (currently only using 2 mainly). If you can suffer down time off and on for a few months it might be something to consider if you think that the price might break your wallet. $300+ plus the cost of tunes (the default PHP library is out of the question for single shots...it's all "custom tunes" once you start down that road) is nothing to sneeze at.
Definitely. My truck is not much quicker (if at all) compared to my original injectors with tunes, but it is a helluva lot stronger.
1) Buy injectors and hydra and get a free set of tunes
2) Buy injectors and send in your TS6 for a free reburn
Option 1 is most definitely the recommended course.
When I was shopping for injectors last year I did not come across any free tunes for injectors. I did buy a bundle so I saved some $$ on the tunes but nothing I was considering had free tunes with it.
Bubba Jones
05-12-2016 11:43 AM
dwnshift79
04-29-2012 02:59 PM
mojoman
05-26-2011 10:24 AM
