Headlight grounds
Old Oct 25, 2018 | 12:30 PM
KOT390's Avatar
KOT390
Headlight grounds
Just a quick question. I am hooking headlights up after having the truck painted. It is a 1970 F100. I have the one ground wire for each headlight that mount on the core support, but the driver side harness has a second ground wire that I can't remember where it went. I'm thinking it mounts on under that turn signal stud, is that right?
I also have a ground strap that was hooked under one of the front bumper bolts but I also can't find where the other end hooked up for that either. It is only 6 inches long. Thanks for any help you can give.
KOT390
WA_PSD
Feb 2, 2012 10:09 PM
lil neet
Sep 3, 2011 12:42 PM
cabloom300
Jun 18, 2010 11:11 PM
elysium
Electrical Systems/Wiring
Feb 7, 2002 01:45 PM
