Thread Sealant
Old Oct 25, 2018 | 11:27 AM
moejr's Avatar
moejr
Thread Sealant
I know there's a thread on this subject but can't seem to find it...... whats the recommended thread sealant for water & oil sender units? The gauges are electrical.I used the shellac stuff in the past but I think there is something better that is used.
Old Oct 25, 2018 | 11:41 AM
Mixer man's Avatar
Mixer man
I use copper anti-seize.
Old Oct 25, 2018 | 01:01 PM
ReForder's Avatar
ReForder
I've used Permatex thread sealant on all the sensors on all my cars, never had a problem
Old Oct 25, 2018 | 04:11 PM
56panelford's Avatar
56panelford
Me too...
Old Oct 25, 2018 | 07:27 PM
Jafo56's Avatar
Jafo56
Me too with the permatex stuff...
Old Oct 25, 2018 | 08:05 PM
56panelford
I've used Teflon tape too
Old Oct 26, 2018 | 08:46 AM
moejr's Avatar
moejr
Teflon tape would work but not sure it's the best sealer to chose when using with electrical senders, the copper anti-seize would have greater conductivity but does it seal out water / oil ok?
I'll check out the Permatex products too.........thanks guy's for your input.
Old Oct 26, 2018 | 10:10 AM
CharlieLed's Avatar
CharlieLed
There is absolutely no way that you can add a tape or sealant to a sender and electrically isolate it. The threads WILL make contact, metal to metal, no matter how you seal them. Don't believe it...try isolating a connection and then put a meter on the two sides, continuity will be read in every case.
Old Oct 26, 2018 | 02:01 PM
Mixer man's Avatar
Mixer man
Technically, pipe threads should not need any sealant at all, it's inherent to the design, but due to manufacturing intolerances sometimes it's necessary. It's been proven over and over many times that Teflon tape makes a great insulator if overly applied, as with any dielectric compound. I've been using copper anti-seize specifically for that purpose in many applications on many different engines and equipment for I don't know how long, and never had a leaking issue.
Old Oct 26, 2018 | 05:30 PM
moejr's Avatar
moejr
Picked up the senders I had ordered from Ford, oil has Teflon & coolant has some red sealant, guess it doesn't matter what ya use.... long as there's no leaks & the gauge works!
Thanks for posting your feedback guy's.
XSoph
May 28, 2018 12:02 PM
SCWIDVICIOUS
North Carolina Chapter
Apr 12, 2007 08:12 PM
Qvan666
Dec 21, 2003 05:32 PM
