How do I adjust my headlights?
Old 10-24-2018, 01:36 PM
Zachary Noles's Avatar
Zachary Noles
Zachary Noles is offline
i bought a new 1986 f150 not to long ago and the headlights were so bad I couldn’t see 15 foot in front of me. So I bought led headlights and I had no problem installing them but I have no clue how to adjust them. Can anyone tell me how to thank you to anyone who does help me out
Old 10-24-2018, 02:20 PM
FuzzFace2's Avatar
FuzzFace2
FuzzFace2 is online now
Received 2,182 Likes on 1,854 Posts
There should be 2 adjusting screws per light, 1 on top and the other to 1 side.
by turning say the top screw in or out will make the light aim higher or lower.
The one on the side to aim left or right.
Only thing I don't know is if you have to pull the head light doors to access the screws,
Dave- - - -
Old 10-24-2018, 09:19 PM
dakotajeep's Avatar
dakotajeep
dakotajeep is offline
My 86 F150 didn't have any doors. The screws were easily accessed with a simple phillips head screw driver
Old 10-25-2018, 02:59 AM
FuzzFace2's Avatar
FuzzFace2
In the field the trim around the head lights on older cars & trucks is called a head light door.
This trim needs to come off when replacing the head light.
Think our trucks use 4 screws to hold them on.
Some doors have notches to fit the screw driver in for adjusting, some dont.
I pulled my truck apart for ground up rebuild 3 years ago so I could not remember if you had to remove them or not.
Dave - - - -
Old 10-25-2018, 07:54 AM
Odisvan's Avatar
Odisvan
Odisvan is offline
theres some video on youtube how to line them up also, that might help you. Something about parking certain feet away from a wall, and measuring your headlight centerline, and so forth and so on. Also, the headlight trim panel, is also called headlight bezel by some folks.
Old 10-25-2018, 08:22 PM
dakotajeep's Avatar
dakotajeep
Dave - - - -
Both of my 1986 F150s headlights are adjustable without removing anything. My thumb and finger below show both the adjustment screws. There is a factory notch to allow access.
Old 10-28-2018, 07:39 AM
Franklin2's Avatar
Franklin2
Franklin2 is online now
Received 1,737 Likes on 1,407 Posts
What I do is find a level parking lot beside a large building (harder to find than you think) and you pull right up to the building wall. Turn the lights on high beam and mark the centerline of the beams on the wall with masking tape. Then back straight up 25ft. With the high beams still on, adjust the centers of the light beams till they line up with the masking tape you stuck to the wall. Then when you put on the low beams, the light should drop down and to the right.
Old 11-19-2018, 11:47 PM
82_F100_300Six's Avatar
82_F100_300Six
82_F100_300Six is online now
Franklin you left out the part where the cops show up during the headlight adjustment
Old 11-20-2018, 06:24 PM
Franklin2's Avatar
Franklin2
I used the side of the factory wall where I used to work.
bearhugger
02-26-2011 05:55 PM
Bananarama
02-11-2010 04:53 PM
mollikate
02-01-2008 04:54 PM
tomfords
Arizona Chapter
01-20-2004 09:34 PM
donstruck
1997 - 2003 F150
12-19-2003 10:33 PM
Quick Reply: How do I adjust my headlights?
