Looks like it is everything for $175. If the rotors are still that clean, I would say it is a great deal. You are going to need new pads as it looks like there is brake fluid on those in the pics!
If I read it correctly, the spindles are not included and are extra $. This conversion will not be possible without the disc brake spindles.
Personally, I would just get the entire front disc brake setup from a donor truck, along with the I-beams and radius arms (I've done this swap 3 times --on a '69 F100, a '72 F100 and on a '65 F100). Having all matching suspension parts means no potential errors of mismatched steering stops, tie rods or other potential problems that can arise from piecemealing parts from one year to another.
If you located a factory front swaybar to put on, the best disc brake/suspension to get would be from a '75-'79 F100/F150. The radius arms on these models already come notched for the swaybar endlink brackets. '74 radius arms have no notches (but can be notched) and '73 radius arms are completely different and have no provisions for being notched.
Thanks fellas. I got some more information from him.
175 for everything. The spindles are still attached to the I beams and come with it BUT the radius arms are not good because he said he had to cut the the nuts off the end to get them loose.
Really wish with the Radius arms were still there. Thoughts?
This is who I picked up my 76 front end from, definitely worth the drive. Everything including the brackets was included.
I just reused my 71 radius arms when I put the 78 discs on my truck. I like them better, and they are one piece as opposed to the 73-79's with the pressed in threaded pin.
The 3/4"-10 pins on the '74-'79 thick gauge stamped steel radius arms are welded in. '65-'73 radius arms are forged steel. If a person is wanting to install a factory '75-'79 F100-F350 front swaybar, the '65-'73 radius arms have no material protruding off the forward ends for the locating pin on the swaybar endlink bracket to engage into.
''74 stamped steel radius arms don't come notched from the factory but, the material is there so that it can be notched. '75-'79 radius arms will already come notched from the factory.
'74 model radius arms I notched to accept the swaybar endlink brackets.
So just to clarify. The parts can be used and will match up the same but I won't have an option for a factory swaybar with my 72 radius arms.
Steering stop alignment between I-beams and spindles can be different (not line up). Tie rod stud diameters can be different as well. This is why I say it's better to get all of the parts from a single donor, to eliminate any potential problems and gotchas for a simple, straight forward installation.
Thanks. That's enough for me to find the right setup.
I didn't see a year on the Dallas craigslist ad. So would the donor parts listed on that dallas ad accept an aftermarket front sway or is the same problem going to exist for those like the ones listed in the Kileen ad. Even though I'm further south I'd be tempted to run up to Dallas for those parts myself if Salty is going to pass on them.
