390 FE clutch replacement
Old Oct 23, 2018 | 06:53 PM
Austin Lowery's Avatar
Austin Lowery
Question 390 FE clutch replacement
I got a 1974 F-100 with a 390 in it. I need to replace the clutch, and it has an 11 inch clutch in it right now. I'm looking to buy this clutch set that is 12 inches though. It says it will fit, but my flywheel may need to be resurfaced. Would this 12 inch clutch fit?
https://www.autozone.com/drivetrain/...25_123613_5233
Old Oct 23, 2018 | 11:36 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C5AZ-6375-K .. 352/360 Flywheel - Use with 11" clutch. (6) 5/16" -18 pressure plate attaching holes on a 12 3/8" bolt circle.
C5AZ-6375-L .. 390 Flywheel - Use with 11 1/2" clutch. (6) 5/16" -18 pressure plate attaching holes on a 12 7/8" bolt circle.
Old Oct 23, 2018 | 11:56 PM
JohnBOV43159's Avatar
JohnBOV43159
You should always resurface the flywheel when you replace the clutch, pressure plate, throughout bearing and pilot bushing anyway.
Old Oct 24, 2018 | 05:51 PM
Austin Lowery
yes, i was planning on doing that, but would the 12" clutch fit on the stock flywheel?
DeeV8er
May 16, 2013 09:47 AM
ATC Crazy
May 13, 2013 02:14 PM
66crawler
Aug 24, 2012 06:09 AM
FLN
Sep 1, 2008 08:14 AM
paulbunyan22041
Apr 2, 2004 07:26 PM
