Acceleration death when cold
Old Oct 19, 2018 | 12:26 AM
fordbozo's Avatar
fordbozo
When cold if I step on the gas it drops, and potentially just dies. When it warms up it runs perfectly. Already put in a new coolant sensor and air temp sensor, which desperately needed replacing. TPS? It never blinks the check engine, it just flat dies. It started getting grumpy on cold acceleration awhile back, but now it just drops dead. It idles just fine, but don't hit the gas. Hit the gas and you get dead, dead, dead.
Old Oct 19, 2018 | 06:52 AM
1986F150six's Avatar
1986F150six
fordbozo,
Perhaps you can tell us which engine and what year? Since you mentioned TPS and "check engine", I'm guessing F.I. and computer. Why not go to an automotive parts house and ask them to read the stored codes? Normally, this is the 1st step and it costs nothing as they hope you will buy your parts there.
Old Oct 19, 2018 | 07:22 PM
fordbozo's Avatar
fordbozo
1986 351 windsor. No check engine light, it just dies flat dead when I step on the gas when cold. If I let it idle and warm up it runs perfectly. Computer replaced along with the air temp and coolant temp sensor.
Old Oct 20, 2018 | 08:19 PM
Franklin2's Avatar
Franklin2
Is this one of those computerized carbed engines? 351w was not fuel injected in 86. If it is a computerized carb, your choke may need some work, and you need to make sure your hot air system on the aircleaner is working and pulling warm air up from around the exhaust manifold.
Old Oct 21, 2018 | 04:13 PM
fordbozo's Avatar
fordbozo
Oops, 1989 351w. Will try again in the correct group. My bad.
NS70250
1983 - 2012 Ranger & B-Series
Nov 30, 2012 07:45 AM
mdula
Jan 11, 2011 12:27 PM
Bax2008
Aerostar
Oct 10, 2008 05:20 PM
viag6
Aerostar
Mar 9, 2004 03:19 PM
vcrmolina
Apr 15, 2002 07:33 AM
