stalling
Old Mar 25, 2002 | 10:30 PM
vcrmolina's Avatar
vcrmolina
Post stalling
After truck starts if truck motor cold and you press on the gas to hard truck will stall . If you want to start it again I must hold
gas pedal now to floor and shut off fuel injector then can not start it only if it starts then dies . This trucks only does it when it
is cold out side . Does this have something to do with the
idle by pass value ? Or is it some other sensor that takes care
of the engine when it is cold ? If anyone has this problem and has fixed it , please let me know what you did . After truck is
warm it runs with no problem .
Old Mar 26, 2002 | 10:09 AM
Ken00's Avatar
Ken00
stalling
It does sound like a sensor problem. The best why to determine which sensor is the problem is to pull the codes from the computer, depending on the year the procedure varies.
Old Mar 28, 2002 | 11:02 PM
Wilber15's Avatar
Wilber15
stalling
If it ain't broke.....change stuff till it is!
To see if it's the idle bypass sensor, unplug the wire going to the sensore while the engine is runing. If the motor shuts down, it is working.
Old Mar 31, 2002 | 10:39 PM
vcrmolina's Avatar
vcrmolina
stalling
This is a 1992 ford ranger . Where is this idler by
pass value located at on this truck ?
Old Apr 1, 2002 | 03:50 PM
Ken00's Avatar
Ken00
stalling
You didn't say which engine but you should find it near/on the thottle body, a round canister (film size) with another thing on the end and two wires coming out of that.
Old Apr 1, 2002 | 11:24 PM
vcrmolina's Avatar
vcrmolina
stalling
The ranger has a 3.0 in it . Thanks for your help .
I will try unpluging the wires when the weather gets
warmer here in Iowa . I will let you know if it works .
Old Apr 7, 2002 | 03:11 PM
tjohnson's Avatar
tjohnson
stalling
FYI. It's an IAC, Idle air control valve.
Travis,
Flatheadv8
*87 ranger STX
2.9, K&N cone, Magnaflow, MSD, Flex-a-lite electric fan
31x10.50 BFG Mud terrains
15x8 Eagle 117's
6" skyjacker
Sikkens silver metallic
Ford grillgaurd, rollbar (off), tubular rear bumper all powdercoated gloss black
Delta crossbed toolbox
Clarion deck/rears, alpine fronts,
Rocford Fosgate-punch 100, punch 250,and 10"XLC
Hella FF100 fog lights
Old Apr 14, 2002 | 09:11 PM
andyroett's Avatar
andyroett
stalling
Vickie
Always check for diagnostic trouble codes first. If none!
One possibility for the cold stall is intake air temp sensoer or engine coolant temp sensor or the wiring. If either sees an intermittant open, the processor thinks it is minus 40 degrees. When you hold the throttle wide open the processor is in dechoke mode (no fuel delivery). This condition does not always set a code.
Old Apr 15, 2002 | 07:33 AM
katdaddy's Avatar
katdaddy
stalling
jeep8589
Feb 20, 2013 05:06 PM
Dreamer99
Dec 14, 2008 04:30 PM
brug79
Jul 27, 2004 07:28 PM
Jofrso
Apr 1, 2003 08:42 PM
cds
Aug 27, 1999 11:12 PM
