2018 F250 CC SB 6.7 ... I checked my oil and noticed it was about 1/8" over the full mark. It was always on the full mark when I previously checked it about 3000 miles ago. Truck has 5800 miles on it with 150 engine hours and 20 idle hours. Coolent reservoir is on max line. I'm thinking diesel in the oil?? Hasn't had an oil change yet. Should I change oil even though the intelligent system hasn't told me too? Am I over thinking this? Thanks
I would. And send a sample to Blackstone Labs to see what's going on (diesel in oil).
It really depends on how long you leave it to settle and stabilize after running. 15 minutes or a full fuel tank on level ground would be full, another 20minutes, slightly over. How long has it sat when you get this reading? I wouldn’t be worried if it had been running, fully warmed up, and only say level once checked after a full hour and it was an 1/8 over. If however it’s under Over that much after only 10 minutes, your overfilled and a change is probably Warrented. I have check after running right away it’s half way up, but when it sits for an hour, it’s full, if not a bit over. For some reason, they seem to be adding a bit to much when changing the oil at the dealer.
Thanks mhoefer, it was 1st thing this morning before I started it, so it was totally settled.
It's important to make all inputs (temps, time, etc) as consistent as possible to take a reading and then concern yourself with this topic.
It is possible that fuel dilution is happening; diesel fuel getting into the crankcase due to regens or leaking injector.
But the only way to know is to be very diligent and track it over the whole OCI.
Also take a sample and send out for analysis; that gives quick confirmation.
If you always check it in the same parked location, after the same time to drain down--even 1/8" isn't enough to worry about, especially with the design of the cable/tool and length. Being on the first oil change, I'd just keep monitoring it.
I agree that where you park is really important. Just a little difference in level makes a difference on the dipstick.
I wouldn't worry about it. This engine is actually designed to accommodate a small amount of "oil growth" based upon fuel dilution. If it continues to increase, then maybe you have a problem.
the truck has the ability to measure (and report) % of fuel in oil if you use forescan / forescan lite you can monitor the oil quality
Interesting ...
I find that hard to believe, from a technical point of view.
There are only a couple trustworthy ways to measure fuel content in lube; they are all done in a lab under controlled conditions.
I suspect this Forscan tool is simply using an algorithm to estimate a %; based on pre-programmed outputs relative to conditional inputs.
Not at all accurate IMO.
Interesting ...
you know its not forscan that develop this....theyre just picking up the readings from something FORD is providing via OBDII...
probably same way ford is calculating % of oil life....sensors, driving conditions, load, math etc
I suppose you could do us the favor and track your oil w/ forscan and sample it - and compare the data you collect.
Interesting ...
You are correct. The engine cannot scientifically determine how much fuel is in the oil. It simply calculates how much it "thinks" might be in the fuel based upon engine RPM, regeneration time, etc, etc. It is probably somewhat accurate since Ford took the time to create this PID...
I also think it is accurate under normal conditions. I imagine it uses things like engine temperature, regens, engine hours, etc. to calculate. It wouldn't necessarily pick up if there was a problem. If PCV flow were restricted, for example. Or if there was a ring seating issue. You could dump a gallon of fuel in the crankcase and the needle wouldn't move on that PID. I think that is the point.
