Gear Selector Adjustment?
Old Oct 15, 2018 | 12:21 PM
Binkowski's Avatar
Binkowski
Hi all,
So I have a 1995 F150 Supercab, 4x4, with the 5.0 and the AODE. My issue is when I put it in to gear, I am not always matching up with letter on the column. I know I need to be a bit to the left of the letter and I try my best to feel the little bump for reverse, then neutral, overdrive, etc etc but to be honest that little click feels like it's getting lesser and lesser.
Is there a cable to adjust? Or is there a selector arm that needs to be replaced after 270 some odd thousand miles? Everything drives and shifts fine with no flashing of the overdrive light or any symptoms of a transmission issue so I am hoping this is a simple inexpensive adjustment/fix.
Old Oct 15, 2018 | 12:29 PM
Freightrain's Avatar
Freightrain
There is a small cable that actuates the indicator from the shifter. Pretty sure there is a threaded nut you can adjust. Pull dash panel and maybe even the column cover, find the little cable.
See the little nut on the lower end of cable? Moving it will adjust the needle.
Old Oct 15, 2018 | 02:47 PM
subford's Avatar
subford
First make sure the screws down low on the column are tight.
Attachment 278054
Old Oct 15, 2018 | 04:04 PM
Binkowski's Avatar
Binkowski
Thanks guys. Now I know where to begin. Will report back what I find.
The_Scatch
15
May 12, 2019 09:06 AM
rupert8
Jul 16, 2014 08:11 AM
midsouth
Oct 21, 2011 07:39 AM
mr. dave
1997 - 2003 F150
Nov 8, 2004 08:47 AM
jbalestri
1997 - 2003 F150
Nov 13, 2003 08:26 AM
