2011 5.0 sparkplugs
Old Oct 14, 2018 | 06:17 PM
akpolaris2's Avatar
akpolaris2
2011 5.0 sparkplugs
I have a 2011 5.0 with 72000 miles on it. I have a knocking that I believe is an exhaust problem but while I tear into I figured that pulling/replacing the plugs may be a good idea also. Is it alright to soak the plugs with PB Blaster before trying to pull them? I understand that they may be stubborn to unfasten. How to I test the coil wires to determine their performance? I have never worked on this kind of system. thanks
Old Oct 15, 2018 | 08:01 AM
bigdaddyII's Avatar
bigdaddyII
PB Blaster isnt necassary on these. The 5.0 engine in the generation is some of the easiest plugs Ive ever changed. Take extra care when releasing the red lock tabs on the coil packs, they are kind of brittle. Other than that, if youve ever changed plugs before these will be a breeze for you.
Old Oct 15, 2018 | 08:38 PM
jdunk54nl's Avatar
jdunk54nl
Also the coil packs can rattle tight to the little holder piece. If you just try to disconnect the wires it is a PAIN. To make it easier, push the COP and the wire attachment together to release that tension and then pull them apart.
Old Jul 26, 2019 | 02:26 AM
akpolaris2's Avatar
akpolaris2
Well I still haven't done this but am threatening to do it soon cause that exhaust noise is pissing me off. Is there a special socket utilized for getting to the plugs? They appear to be deep in the hole..
Old Jul 26, 2019 | 10:55 AM
DMMAN's Avatar
DMMAN
You need a 5/8 spark plug socket with an extension. I used electrical tape to ensure the socket was secured to the extension. Also mine were on quite tight so I used a pipe around the ratchet to get be a little more torque but ease into it, you don't want to bust it. It is very simple. Coil bolt is an 8mil.
Old Jul 26, 2019 | 05:16 PM
big mule's Avatar
big mule
Watch a YouTube video before you start. It’s really a easy job.
Old Jul 27, 2019 | 11:09 PM
akpolaris2's Avatar
akpolaris2
What are recommended as replacement plugs?
NotSoSporty98
Feb 23, 2016 06:30 AM
Tommy B405
Aug 5, 2015 07:38 AM
aceltx09
Aug 25, 2010 09:46 PM
Trek93023
Modular V8 (4.6L, 5.4L)
Apr 11, 2004 08:15 PM
rayban33
May 12, 2003 09:23 AM
